Best HD Driveshaft??? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 01-01-2010, 02:54 PM Thread Starter
dieselford755's Avatar
Where is the best place to buy a new driveshaft, mine has over 200,000 and mechanic says its starting to wear out, Not the u joints, Is there a indestructable aftermarket one?
2002 F25O Supercab 212,090 intake,AIC delete, PI Converter with Suncoast Xtreme Rebuild. DP-tuner 60 TOW, 4in exhaust straight exhaust out the side tire. Garrett Ball Bearing,Top Gun bumbers, Lots of LINE X , Issopro guages, titan fuel tank, New Alliants Injectors and UVCHs, Royal Purple throughout drivetrain, Rotella 5w40 Synthetic oil, Lots of blowby, rusty pan hoping for new motor this year!!
dieselford755 is offline
post #2 of 6 (permalink) Old 01-01-2010, 03:34 PM
My Photos: (19)
This hasn't been discussed much here, but a search should find you a few posts. Most people will just rebuild their stock one with new parts or take it to their local driveshaft shop.
I've had a new one piece shaft build by Tom Woods Custom Driveshafts, but with the biggest parts he had available. Best suggestion is to find a local shop that does work on bigger trucks. They will have access to larger parts than most 'off-road' or 'jeep' places.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #3 of 6 (permalink) Old 01-01-2010, 04:16 PM
Do you get any vibration from a one piece D/S that long? I've been having a prob with mine since the driveline shop cut the harmonic balancer off the end of mine. Still trying to resolve that issue.
2000 F250 7.3L Auto. CC 4X4 Lariat SB, 3.5 Fab Tech lift, 16X10 Typhoons 305/70/16 BFG's, AFE Stage2, Banks Big Head, Banks Exhaust, Bellowed up-pipes, Quadruple gauges, Wicked Wheel, Trans Go shift kit, Eaton TrueTrac, DP-Tuner F5, Stock, 60T, 60E, 80E, 120R.
JamieWS6 is offline
post #4 of 6 (permalink) Old 01-01-2010, 04:50 PM
My Photos: (19)
No, I get vibrations from my tires being crap, but not from the driveshaft. I think it was about 73" long which is about the longest they would make in a single piece. I've not done anything to change angles either. Other than the wedge shaped blocks in the rear.
BTBBT is offline
post #5 of 6 (permalink) Old 01-03-2010, 07:12 AM
Maintain's Avatar
Hmm. Mine is also nearing 200,000 miles. What does the mechanic mean by "wearing out".
PS... I've been drag racing and sled pulling one mine for a few years now. Still rides down the road smooth.
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
post #6 of 6 (permalink) Old 01-03-2010, 09:40 PM
Tony_ONeil's Avatar
I'm also curious on this one. The joints can wear out as well as the carrier bearing, but those can be easily replaced.
2002 F-350 Crew Cab Lariat 4x4 7.3L Auto SRW
AFE Stage II Intake, AFE 4" Turbo-Back Exhaust, CCV Mod, Zoodad Mod, Pre-pump Mod, Flex-A-Lite Tranny Cooler, Draw-Tite Activator II Trailer Brake Control, IC Foil Wrap Delete, 203 Thermostat, Ford reman. Turbo, Fleetrite HD ELC, Rotella 5w-40 Synthetic, 4300K 35Watt dual beam HIDs, DB High-Torque Starter, Isspro EV gauges (trans,boost,pyro)
Tony_ONeil is offline
