big problem the truck shakes I need help - Diesel Forum - TheDieselStop.com
post #1 of 316 (permalink) Old 12-05-2006, 04:04 PM Thread Starter
Hi guys
Yesterday I was trying to track down this oil leak, I finally found it today it was the oil dipstick pipe was loose and it came out of its hole...... anyways when I went to start up the truck yesterday the SES light was on and it still hasnt gone off the truck shakes really bad when you accelerate it is more noticeable in some rpms then in others like at 1500 rpms the trucks shakes really bad. and in some of the higher rpms its not as noticeable.
I went to autozone to use one of their code readers, it read that their were no codes so I couldnt clear the SES light.
could the chip be loose?
What could be causing this problem?
Ford F550 Crew Cab 4x4 with Fontaine Bed and Air
00PSD1 is offline
post #2 of 316 (permalink) Old 12-05-2006, 04:14 PM
Kanman's Avatar
Re: big problem the truck shakes I need help
post deleted
Kanman is offline
post #3 of 316 (permalink) Old 12-05-2006, 04:15 PM Thread Starter
post deleted
00PSD1 is offline
post #4 of 316 (permalink) Old 12-05-2006, 04:16 PM
ptsuperd's Avatar
My Photos: (28)
Not a chip problem.
Tranny would be my first guess.
ptsuperd is offline
post #5 of 316 (permalink) Old 12-05-2006, 04:17 PM
ptsuperd's Avatar
My Photos: (28)
Gregrob. Buddy of Bigrpwr and kelly coon.
ptsuperd is offline
post #6 of 316 (permalink) Old 12-05-2006, 04:21 PM
bigrpowr's Avatar
flight # 6666 lax to houston arriving 5:30 cst 2 hours to beaumont then it's on miller boy.
2000 F350 4x4 almost fast
12.27 @112.89
12.80 @ 114.48
727.7 hp (NOS)
bigrpowr is offline
post #7 of 316 (permalink) Old 12-05-2006, 04:22 PM
ptsuperd's Avatar
My Photos: (28)
LMAO! You know I'm ready. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Just checkin to see if you were awake rollerboy. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
ptsuperd is offline
post #8 of 316 (permalink) Old 12-05-2006, 04:23 PM
CSIPSD's Avatar
My Photos: (52)
Or a loose injector harness... Under valve cover harness...
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #9 of 316 (permalink) Old 12-05-2006, 04:28 PM
you have a miss in one or more of the cylinders check the harnesses on the valvecovers to the injs first, if not pull the valve covers and make sure all connections are secure on the injs i had one pop off on my way back from school last year which resulted in a dead miss (inj didn't fire) .
on edit: exactly what they said ^^^ check the connections!!!
2002 F250
DarkShadowDiesel is offline
post #10 of 316 (permalink) Old 12-05-2006, 04:29 PM
Kanman's Avatar
post deleted
Kanman is offline
post #11 of 316 (permalink) Old 12-05-2006, 04:33 PM Thread Starter
Kanman thats ok
Last night when I took off the valve cover I I made sure all the injectors were connected and I pushed to two main harnesses together. I will look at harness first if thats not the problem I guess I will take her apart one more time and see if that fixes everything
thanks,
Andrew
00PSD1 is offline
post #12 of 316 (permalink) Old 12-05-2006, 04:34 PM
CSIPSD's Avatar
My Photos: (52)
What the heck ever happened to that kid? Used to post on EVERY forum... now he dropped off the planet...LOL
Have your EGT's dropped? When my harness came loose the drivers side pyro was at 200 at 35mph!!! So I guessed it was the drivers side...LOL
Joe
CSIPSD is offline
post #13 of 316 (permalink) Old 12-05-2006, 04:37 PM
Kanman's Avatar
post deleted
Kanman is offline
post #14 of 316 (permalink) Old 12-05-2006, 04:38 PM
Do you have a non contact thermometer? The "point and shoot" kind? If you don't find one, and aim it at each exhaust manifold outlet from each cylinder. You will find the coldest one(s) and then you find which ones ain't firing. Either that, or a contribution test, or a switch box.
'03 F-250
'01 F-550
Boonman is offline
post #15 of 316 (permalink) Old 12-05-2006, 04:49 PM Thread Starter
GregRob was banned from TDS.
Anyways I disconected the batteries for 15 minutes and reconected them but the SES light doesnt go away. Autozone code reader so their were no codes.
I dont have a non contact thermometer unforutently.
At 35 mph 1700-1800 rpms my egts were at 900.
00PSD1 is offline
