Blue spring mod for 7.3L? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 06-20-2014, 12:20 AM Thread Starter
jleedog's Avatar
Has anyone done the blue spring fuel pressure mod on their 7.3l? Or is this mod only for the 6.0 I have done some searching of the forums and haven't found much.Would you recommend this mod to improve performance if it can be done to a 7.3l?
P.S If you have a ford part number that would be appreciated.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #2 of 9 (permalink) Old 06-20-2014, 12:24 AM Thread Starter
jleedog's Avatar
I found this after some more searching. Can anyone confirm?
Fuel Pressure Regulator Repair Kit (contains spring, valve spool & new brass plug)
(Ford) F6TZ-9K061-AA (CA emissions)
Fuel Pressure Regulator Spring
(International) 1825854-C1 (CA emissions)
jleedog is offline
post #3 of 9 (permalink) Old 06-20-2014, 02:10 AM
Googs's Avatar
I think this is the kit your after.
Replacement Fuel Pressure Relief housing - Billet Aluminum w/pressure shim springs
  1. 58-61 psi silver spring (Stock pressure)
  2. 62-65 psi gold spring
  3. 67-70 psi black spring
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #4 of 9 (permalink) Old 06-20-2014, 05:03 PM
blue99stroker's Avatar
googs pointed you in the right direction.
when doing the billet fpr housing i would rebuild the rest of the fpr as well.
dieselorings sells a rebuild kit and billet fpr.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #5 of 9 (permalink) Old 06-20-2014, 08:20 PM Thread Starter
jleedog's Avatar
Have you or anyone you know done this mod? Which spring should I use the gold or black to increase fuel PSI and give my truck more power?
jleedog is offline
post #6 of 9 (permalink) Old 06-21-2014, 02:48 AM
Googs's Avatar
I use the gold spring , you won't notice any big difference in power, it will lift your F/P and atomize the fuel better.
If you are after more power you need other components.
Fill you signature in and we can see what mods you have already and you can be advised better.
Googs is offline
post #7 of 9 (permalink) Old 01-15-2017, 12:13 AM
Relentless007's Avatar
I apologize in advance for reviving an old thread and asking a what may be a dumb question. Would the blue spring mod ba applicable to my 97' 7.3 ? I just never see anyone talk about it for the OBS trucks.
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #8 of 9 (permalink) Old 01-15-2017, 10:11 AM
The blue spring in the kit works to raise fuel pressure.
post #9 of 9 (permalink) Old 01-15-2017, 08:47 PM
yan7gin's Avatar
Here's
http://www.dieselorings.com/7-033-fp...m-springs.html
The gold one is what most people will use in their 7.3
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
