Boost gauge sensor placement - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 06-19-2019, 04:34 AM Thread Starter
Which location is best for the boost sensor on a 7.3, thru the intake air heater port or to drill and tap just above it?
Howard Avery is offline
post #2 of 4 (permalink) Old 06-19-2019, 06:26 AM
2000F250-7.3's Avatar
I would use the heater port that is wear mine is at it gives a clean look. It also gives you a true reading of how much boost the engine is getting.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #3 of 4 (permalink) Old 06-19-2019, 07:23 AM Thread Starter
Thank you sir. That's what I'll do.
post #4 of 4 (permalink) Old 06-19-2019, 12:52 PM
klhansen's Avatar
My Photos: (180)
An even easier route is to put a tee in the MAP sensor hose and run it to your gauge/sensor. It's already connected at the base of the turbo outlet spider below the IAH port.
), AIS,
regulated return,
klhansen is offline
