boost issue - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 02-22-2011, 06:00 PM Thread Starter
907stroker's Avatar
boost issue
so i just went for a drive and washed my truck and on my way i was watching my boost gauge and it didnt move much, apon going from a stop light it would show about 10 right before i shift. and cruising at 55 it was about 4. and at wot it would get about 16 but would take a long time to get there. like half a mile of wot. . my egts are always about 400, and when cold 600.
i also have some oil on the top of my engine the the "valley". and looks like the bottom of the turbo is a little dark in old oil. the truck has 248,688
really need help my dp f5 is on its way and i dont want to blow up something
99 f250 6 speed, pretty much stock, extra heavy suspension, dp tuner f5, intake
907stroker is offline
post #2 of 13 (permalink) Old 02-22-2011, 06:04 PM
mwe-maxxowner's Avatar
Send a message via AIM to mwe-maxxowner
16-17 lbs is about max on a stock truck.
87 f250 4wd LB ex cab 460 bored .60 edelbrock intake, towing cam glasspacks-6 mpg 8 on good day- my pride & joy once towed my '85 j-co j-crane 28' 5er
99 F250 7.3(engine stamped june of '99) 250K white ex cab lb, 2wd
jl audio slash 4ch amp, jl 8" sub, focal components front, infinity coax rear, 10 disc changer
-tymar intake, no muff
-bullydog egt, autometer boost
-f5 chip w/80t, 80e, 60t, 100, 140 extreme(140 is amazing!)
Garrett 38r
Chrome fender trim, 265 nitto terra graps, nerf bars, billet grille, '06 headlights, chrome door handles, louvered 5er tailgate
mwe-maxxowner is offline
post #3 of 13 (permalink) Old 02-22-2011, 06:09 PM Thread Starter
907stroker's Avatar
at just wot? what should i be seeing when im just cruising? and at times at cruise it just spools up to about 10 for a few seconds
post #4 of 13 (permalink) Old 02-22-2011, 08:29 PM
The turbo is heat driven so thats why the low boost on the freeway. Get your DP in and take the hose of the waste gate. I pulled 40psi like this. Not good for long periods of use as the turbo can't take it.
Courage is not the absence of fear but being afraid and moving forward anyway.
kiarasue is offline
post #5 of 13 (permalink) Old 02-22-2011, 08:54 PM
lariat 7.3's Avatar
Send a message via AIM to lariat 7.3
i get like 1-2 cruising at 60 so i guess i have some leaks?
2000 f 250 4x4. ccsb
just hit 218,000
38R with Turbo Master
238/80% hybrids
Riff Raff FRx
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
lariat 7.3 is offline
post #6 of 13 (permalink) Old 02-22-2011, 09:01 PM Thread Starter
907stroker's Avatar
haha, i dont think i will do the "red tube mod" doesnt sound right to me. but isnt my turbo supposed to spool quicker then it is. it takes forever to get past even 15. idk maybe im paranoid
post #7 of 13 (permalink) Old 02-23-2011, 12:30 PM Thread Starter
907stroker's Avatar
maybe, i just watched today and when i was just cruising at 65 i was getting 6-8 on flat road
post #8 of 13 (permalink) Old 02-23-2011, 03:13 PM
lariat 7.3's Avatar
6-8? dang at 65 ive got about three. but can hit 25 no problem
just hit 218,000
238/80% hybrids
Riff Raff FRx
remote start.
AIH cut off
bypass oil system
running on WMO!
post #9 of 13 (permalink) Old 02-23-2011, 04:06 PM Thread Starter
907stroker's Avatar
and i cant get hit over 15 haha
post #10 of 13 (permalink) Old 02-23-2011, 04:30 PM
lariat 7.3's Avatar
you dont have a chip yet. you need the extra fuel for added boost
just hit 218,000
238/80% hybrids
Riff Raff FRx
remote start.
AIH cut off
bypass oil system
running on WMO!
post #11 of 13 (permalink) Old 02-23-2011, 05:54 PM
Cruising at around 60 with a tune without going uphill, pulling, etc, I see only 4-5 lbs. I wouldn't think your boost numbers are too far off for a stock truck. I know I have no boost leaks. If I hammer into it, boost will easily climb to around 26 or 27 lbs on my truck before ses light comes on and I back out of it.
If you're that concerned, dieselsite has a nice boost leak detector for about 65 bucks.
If you put a chip in, and you still can't get much over 20 lbs, then I would start to look into a potential boost leak.
Just for peace of mind, you could check all your intercooler boots, just to make sure they are nice and tight.
Garrett 38r
post #12 of 13 (permalink) Old 02-23-2011, 07:28 PM Thread Starter
907stroker's Avatar
anyone know about removing an old edge chip or programmer? it came with my truck and i need to take it out before my dp gets here. or can i leave it?
post #13 of 13 (permalink) Old 02-23-2011, 07:31 PM
lariat 7.3's Avatar
take it out
just hit 218,000
238/80% hybrids
Riff Raff FRx
remote start.
AIH cut off
bypass oil system
running on WMO!
