Bully Dog CT Tuner Questions - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-15-2019, 12:26 AM Thread Starter
Can you interchange gas and diesel tunes between the bully dog ct gas and the bully dog ct diesel? They seem like similar units and the book that came with it has both gas and diesel engines in it saying it's compatible. Plus, when I went to update the micro sd on the bully dog website it had options for both on the update agent.
Whiskey_helpz is offline
post #2 of 2 (permalink) Old 08-15-2019, 12:46 PM
No you cannot. Gas only works on gas and diesel only works on diesel.
DonWarkentin is offline
