Can a 7.3L with a 4R100 auto benefit from an exhaust brake? - Page 3 - Diesel Forum - TheDieselStop.com
post #31 of 36 (permalink) Old 01-27-2019, 05:22 PM
Big Horn's Avatar
Originally Posted by farnorthdriver View Post
Also Big Horn, Here's a very minor point you may have already thought of. What I did to make the DP-Tuner decel program easier to use was to make it the very last program. That way when you're heading downhill and focused on the road all you need to do is hit the "+" button on the tuner multiple times and it will end up in the decel program. Better than having the decel program #4 of 7 programs and having to push the tuner button a precise number of times.
Makes sense— I’ll have to look at the DP Tuner closer. Does it have a digital display then of the tune it’s on?
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #32 of 36 (permalink) Old 01-27-2019, 05:57 PM
blue99stroker's Avatar
Ask Jody if he turns the decel off when exhaust backpressure is in excess of 60 psi. I’d have to say he doesn’t. Because i know another tuner who was trying to write a decel tune and couldn’t safely do it.
Because brand new factory exhaust valve springs only hold 75 psi. Add in a lot of miles and seat pressure is going to be less.
That’s how you float a valve and ruin a 7.3
If your going to run an exhaust brake it’s highly recomnended to install new valve springs
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #33 of 36 (permalink) Old 01-28-2019, 10:56 AM
Big Horn's Avatar
I’ve went back and did a search on upgrading to heavier valve springs, General information, suppliers, and youtube/ replacement without removing heads. I’m seeing upgraded springs rated for 99 psi and then upgraded springs with the compressed height shortened for 125 psi but they all seem to reference this upgrade as being made for built up motors running high Boost. Is there a trade off or negative aspect to going to the heavier (99 psi) springs with a stock 7.3 / normal boost engine, just for the sake to accommodate the use of the EBPV as an exhaust brake? I guess what I’m getting at is there has to be a reason FORD designed it with the stock 75 psi springs.
Big Horn is offline
post #34 of 36 (permalink) Old 01-28-2019, 11:19 AM
No issues running a stronger spring.
No excessive rocker wear or anything.
Shimmed .910’s are the cheapest
Beehives are more geared toward performance engines.
Ford didn’t plan on us running so much boost/exhaust drive pressure.
post #35 of 36 (permalink) Old 03-07-2019, 04:57 PM
Question Van transmission 4R100 & exhaust barke ...doable or not ?
Hi ,I am looking for exhaust brake kid for my 02 E450 cataway super duty 7.3 turbo diesel 16V vin 1FDWE45FX2HA61288 transmision 4R100 20 bolts pan ......... the end tail pipe is 3 1/2 " near engine 3 " 1/4 ....... what part # fit ???
I heart that EXHAUST BRAKE 1027144/ c40019 fits only pick ups F350 !!!!???? - 14 bolts transfer case -
My is 20 bolts E450 transmision 4R100. !!!!!
I want to make sure it will work with the comp without tranmission damage thanks in advance for your help .
PeterD is offline
post #36 of 36 (permalink) Old 03-07-2019, 05:04 PM
Hi ,what did you find out ? I am looking for exhaust brake kid for my 02 E450 cataway super duty 7.3 turbo diesel 16V vin 1FDWE45FX2HA61288 transmision 4R100 20 bolts pan ......... the end tail pipe is 3 1/2 " near engine 3 " 1/4 ....... what part # fit ???
I heart that EXHAUST BRAKE 1027144 C40019 fits only pick ups F350 - 14 bolts transfer case - mine is 20 bolts E450 transmision 4R100.
I want to make sure it will work with the comp thanks in advance for your help .
PeterD is offline
