DC Power 190 Amp Alternator - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 08-14-2019, 07:25 PM Thread Starter
Swamp_Fox's Avatar
My alternator died on me last week so I decided to invest in a DC Power 190 amp alternator for my '02 7.3. Installed and cranked up. My battery light went right out. I let it idle for about 10 minutes and checked at the posts with my meter. I was getting 14.23-14.24 on the passenger side battery and 14.21-14.22 at the driver's side battery. I will give it a week and comment on anything noteworthy. It's built like a tank. I hope it lasts for quite some time. Anyone else with this alternator please chime in with your opinions since you have had one. Thanks
2002 F250 Lariat 4x4 Crew Cab Short Box 7.3L
Swamp_Fox is offline
post #2 of 3 (permalink) Old 08-14-2019, 07:47 PM
bugman's Avatar
My Photos: (12)
Did you upgrade the charge wire to the battery aslo?
Sent from my SM-J737V using Tapatalk
bugman is offline
post #3 of 3 (permalink) Old 08-15-2019, 12:10 AM
https://www.dcpowerinc.com/collectio...pper-cable-kit
Here's the link to the charge wire just in case you didn't get it yet.
DonWarkentin is offline
