Dealership re-flash my PCM? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 05-24-2005, 09:18 PM Thread Starter
wfdbackdraft's Avatar
My Photos: (14)
A friend told me that I should take my truck to the dealership and let him adjust my PCM for my bigger tires, and while he's in there, download any new "updates" for the PCM. Does this sound like a good idea? I'm thinking about getting a chip from Jody soon. Would he be doing the same thing(updates + correct tire size) in his custom burnt chip? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2002 F350 CC SRW 4x4 7.3 Powerstroke.
Full Force Injectors - Stage 1 Single Shots
DP Tuner F6 chip, with custom tunes
4" Exhaust, from the turbo, back to the 5" Chrome stacks
4" Superlift front springs, air bags in the rear and Bilstein shocks all the way around.
315 75 R16 Nitto Terra Grapplers.
Isspro EV Gauges...AIH delete...zoodad mod...Tymar air filter...FPR shimmed to 70 psi. Custom $10.00 grill.
Cobra 29LTD Classic with a Wilson Trucker SW2000 mounted on a custom cowl antenna mount.
wfdbackdraft is offline
post #2 of 5 (permalink) Old 05-24-2005, 09:26 PM
SeeYa's Avatar
Re: Dealership re-flash my PCM?
The tire size calibration is in the abs module. But he can change the shift points to match the tire size in the programming.
Diane Tipton
DP-Tuner®-co-owner/ Customer Service
Proud Sponsor of The Diesel Stop since April 2005
[CENTER]
Home of the original F5 multi-position chip, F6 Smartchip, INFINITY-dx, Infinity Mini & C.E.I.-hub
[FONT=Georgia][SIZE=3][COLOR=White][B][CENTER]
[COLOR=Black]Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
post #3 of 5 (permalink) Old 05-24-2005, 09:50 PM Thread Starter
My Photos: (14)
Is that you Jody?
Should I let the dealer do what my friend suggested? I mainly want my speedo, and odometer back to normal. Are there updates to my PCM's original burn?
Do your flashes increase the line pressure of the transmissions? And would you till recomend that Sonnax valve?
post #4 of 5 (permalink) Old 05-24-2005, 10:02 PM
SeeYa's Avatar
The chip will over ride the PCM code. The tire size can be allowed for in the programming.
Diane
Diane Tipton
[CENTER]
828-221-0076
SeeYa is offline
post #5 of 5 (permalink) Old 05-25-2005, 08:15 AM
SmokeyWren's Avatar
My Photos: (45)
Controversial. Ford engineers determined that the original PCM program had a bug that needed fixin', so they fixed it. But the fix might cause other things to be different, too. From your viewpoint (not the Ford engineers) some updates are better than the old program. Some are not.
Not exactly. I think what Diane (Jody's better half) is saying is that he can optimise the way the engine runs and the tranny shift points, but not the speedo calibration. Because the speedo calibration is in the ABS module - not the PCM. So if you want an accurate odo or speedo, then have the dealer change the tire revs/mile in the ABS module.
If you're going to have Jody do a custom chip for you, then it doesn't really matter which PCM code he begins with. But he'll need to know that PCM code. So if the dealer re-flashes your PCM, be sure to get either the code or the new PCM part number so you can give it to Jody when you order your chip.
My Sierra Blanca (Spanish for White Mountain) in the sig pic was a great pickup for 11.5 years. I sold it several years ago. I drove a hand-me-down 2003 F-150 SuperCrew 4.6L 2V for a while, but it was unacceptable for towing more than a rowboat. Replacement is a 2012 F-150 EcoBoost SuperCrew Lariat that tows my 5,000-pound TT like a dream. Replaced the 2012 with a 2019 F-150 3.5L EcoBoost with max tow.
SmokeyWren is offline
