Ebpv delete electrical question need help - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 6 (permalink) Old 09-01-2016, 02:09 PM Thread Starter
So I just recently did the non-E BPV pedestal conversion kit and now I am wondering what do I do with that plug that went into the solenoid sensor on the original pedestal. Do I just leave it hanging, is there a bypass pigtail set up for it or can you use resistors for it
7.3Lifestyle is offline
post #2 of 6 (permalink) Old 09-01-2016, 06:26 PM
Connect the solenoid to the plug and leave it in the engine valley. This will prevent a code being thrown for it.
StockKnocker likes this.
post #3 of 6 (permalink) Old 09-02-2016, 02:02 PM
blue99stroker's Avatar
470 ohm 1/2 watt resistors. 5 bucks
Delete plug from riffraff 40 bucks.
Cut the old plug off the other pedestal-free
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #4 of 6 (permalink) Old 09-02-2016, 02:21 PM
SuperDutyTrooper's Avatar
My Photos: (6)
Diesel-O-Rings sells the resistor for $1.00. Go to their website and look under the "SHOP SUPPLIES" tab.
2000 F250 Ext Cab Longbed 7.3 4x4 ZF6 "The Pride of America" - AEM air filter, BTM exhaust, CNC Fab HPOP lines, CNC Fab 4-line stainless fuel lines, Fluidampr harmonic balancer, LuK improved clutch kit, Melling LPOP, DieselSite coolant filter, 203* thermostat in billet housing, 3 gauges (boost, pyro, fuel pressure) in pillar mount pod, AIH delete, EBPV delete, CCV mod, Zoodad mod, Glow Plug Relay relocation mod, Hutch mod, Harpoon mod, MileMarker manual locking hubs.
SuperDutyTrooper is offline
post #5 of 6 (permalink) Old 09-02-2016, 04:44 PM
Well an 8 pack from radio shack is 4 bucks lol
post #6 of 6 (permalink) Old 09-13-2016, 07:58 PM
StockKnocker's Avatar
I did exactly what Justin said.^^^ Remove the sensor unit from the old pedestal. Remove any extra weight. There is a blue aluminum sleeve,etc. Next, I wrapped it with black racing repair tape and zip tied it up out of the valley. I didn't want it rolling around in there. Works fine and no codes. Best part was I cleaned up the old pedestal with brake clean and sold it on eBay for $100! Guys with pre-99's will buy them. Cheers!
-Jason
2003 E-350 7.3 PSD EB, RR Frx & Hpx,Hutch/Stanadyne FM100 Pre-Filter, WW2, EBP delete pedestal/Hi flow outlet, Spectra Premium F41B Fuel Tank, 203* tstat, & coolant filter, Bellowed/wrapped up pipes, Walker BTM, AIH delete,AM EGT/TRANS/FP gauges, ThermalZero turbo blanket, KYB MonoMax shocks, TTC-2814 HD coils, Ford Ambulance Steering Stabilizer, Michelin 285-17ís Load Range E, Rear 10 leaf packs, CCV slightly modified, full sound mat, Curt Class V Rear Hitch and 2" Front Hitch, Tekonsha Primus, Nav., 2 AGM's, 2000 lb. roof rack, inverter, insulated, custom bulkhead, tool bins, 170k, my 18th
SOLD: 1997 F-350 7.3 PSD, 4X2, XLT, CC, LB, STD, 240K and counting
SOLD: 1996 F-350 7.3 PSD, 4X2, LB, AUTO, 175K and counting
StockKnocker is offline
