Engine breaks down at 3000rpm - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 06-10-2013, 01:10 PM Thread Starter
The truck is classed as an early 99 but i have updated everything except HPOP to 99.5-03. Injectors are AD. Turbo is BD Turbo Thruster 2. intake is AFE. Tuner is Edge Evolution on high. Defuser boost fooler. Stock air box removed and a fleetguard installed. 4 inch down pipe to 5inch strait pipe. Here is the problem when it hits 3000rpm it starts to flutter or break up. The funny part is its getting 30psi boost. The sending unit was removed and the 2 filters cleaned. Installed a new lift pump and fuel filter and still doing it. I am thinking IDM is the culprit but i want to hear more ideas. Oh and bellowed up pipes installed as well. It a manual trans as well . EBV deleted.
Allan3306 is offline
post #2 of 5 (permalink) Old 06-10-2013, 01:19 PM
klhansen's Avatar
My Photos: (180)
With all the mods you have, I've moved your post to the Upgrades and Aftermarket Forum.
Someone here should be able to give you some ideas.
Welcome to TheDieselStop.
), AIS,
regulated return,
klhansen is offline
post #3 of 5 (permalink) Old 06-10-2013, 04:33 PM
Maybe your boost fooler isn't working and it's defueling.
brotherxb is offline
post #4 of 5 (permalink) Old 06-10-2013, 04:43 PM
timmygarret's Avatar
Feedback Score: -1 reviews
sounds like defueling, but why are you reving to 3000 rpms?
2000 F250 4X4 Super Duty V8 7.3L Powerstroke. 125,000 miles and counting
Extended cab Lariat, Auto. 6 position bully dog chip. Tymar intake. MBRP 4in exhaust, 6in tip. Strictly Diesel Boost Fooler, HPOPX and Riff Raff FRX, Cobalt gauges pyro, trans temp, boost. Zone 2.5in front leveling kit, Rode Master rear overload springs. Grill Guard, Mud Flaps, and Lots of LED lights!
timmygarret is offline
post #5 of 5 (permalink) Old 06-10-2013, 08:01 PM
Is it from the edge? I set mine at 3700 rpm
F250 SD
diy intake
4 inch turbo back
ccv dumped outside
paulf250 is offline
