Engine build - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 24 (permalink) Old 06-03-2017, 07:43 AM Thread Starter
Whiskyb's Avatar
Engine build
I have a thread already asking weather a 99 7.3 I was considering buying would fit in my 01. http://www.thedieselstop.com/forums/...ll-fit-613985/ I now have it stripped down to just the short block. Cylinder walls have very little ridge maybe a few thou. Bearings look good on mains and rods. My plan which is open to change was to take it to the machine shop and let them tank it and install new cam bearings,and do the cylinder walls however they feel is right. Maybe re-use the stock pistons or buy one of the complete kits that include everything. Since I have access to my 01 engine as well what parts are better if any between the two. I will be using the better rods as informed in previous thread from the 99. Any difference in heads, manifolds that I should be aware of? Its not going to be a super power build but anything that helps while I am doing this would be greatly appreciated. I have built many a gas engine, this will be my first diesel, so any advice would also be appreciated Thanks
Whiskyb
2001 F350 4X4 Super Duty PSD Dually
Almost 400k and still given her
DP Tuner
and guages, DIY air intake, BTM,
Dieselsites trans and coolant filters
Wicked wheel 2 (Gone) , Guzzles billet fpr
Whiskyb is offline
post #2 of 24 (permalink) Old 06-03-2017, 10:03 AM
RT
RT's Avatar
Sounds like you're on the right track. There are no other part difference between the two motors. I'd have the machine shop remove any ridges and lightly hone the cylinders. New rings and bearings, a new oil pump and call it a day. I'd have them clean up the heads- that's usually pretty inexpensive. There would have to be some pretty convincing evidence to let them talk you into boring the cylinders.
Sent from my iPad using Tapatalk
RT is offline
post #3 of 24 (permalink) Old 06-03-2017, 10:07 AM
Early 99 had different intake and turbo.
DENNY
DENNY is online now
post #4 of 24 (permalink) Old 06-03-2017, 11:53 AM Thread Starter
Whiskyb's Avatar
Just went out and bought the ridge reamer. Sunny today so its going to be yard work. Rain tomorrow so it will keep me in the garage using my new tool
Whiskyb
DP Tuner
Whiskyb is offline
post #5 of 24 (permalink) Old 06-05-2017, 03:20 PM Thread Starter
Whiskyb's Avatar
Dropped the block off at the machine shop today. Waiting for any good/bad news. As a side note I had to chainfall the engine into the back of my jeep. Had to remove the hardtop to get it in. That block even bare is heavy
2000F250-7.3 likes this.
Whiskyb
DP Tuner
Whiskyb is offline
post #6 of 24 (permalink) Old 06-05-2017, 08:09 PM
klhansen's Avatar
My Photos: (180)
You got that right!! I was barely able to dump my bare cracked block out the back of the truck at the scrap yard. It did increase the money I got as scrap compared to a gas engine though.
), AIS,
regulated return,
klhansen is offline
post #7 of 24 (permalink) Old 06-09-2017, 03:12 PM Thread Starter
Whiskyb's Avatar
Cylinders 19thou out of round. Waiting on crank results. Evidence is pretty much confirming higher mileage and possibly bad maintenance.
Whiskyb
DP Tuner
Whiskyb is offline
post #8 of 24 (permalink) Old 07-01-2017, 07:41 AM Thread Starter
Whiskyb's Avatar
Ended up machining cylinders and crank. Will be taking the heads to them this week. Are there any issues I should be aware of or common problems with these heads? Is there anything I should have them do while their at it?
Whiskyb
DP Tuner
Whiskyb is offline
post #9 of 24 (permalink) Old 07-01-2017, 10:23 AM
RT
RT's Avatar
No known issues. No cracking issues at all - unlike the 6.0 and 6.4. Just a good valve job and you should be good for another half million miles or better.
RT is offline
post #10 of 24 (permalink) Old 07-02-2017, 01:48 PM Thread Starter
Whiskyb's Avatar
That's what I wanted to hear.
Whiskyb
DP Tuner
Whiskyb is offline
post #11 of 24 (permalink) Old 07-25-2017, 01:54 PM Thread Starter
Whiskyb's Avatar
Are the camshafts the same between a 99 and 01? Usually as the years go on the manufacture puts a little more hp and torque into the new models and I was just wondering what parts are better. Are the aftermarket camshafts worth it for a daily driver?
Whiskyb
DP Tuner
Whiskyb is offline
post #12 of 24 (permalink) Old 07-25-2017, 04:01 PM
RT
RT's Avatar
No difference in the part number. All the extra HP was through tuning. Personally, I don't think an aftermarket grind is worth it. These things run so well with the stock cam, I'd just stay with that.
RT is offline
post #13 of 24 (permalink) Old 07-25-2017, 05:25 PM
I would think the piss poor air filter housing Ford used probably allowed it to get dusted and it wore cylinder walls. Usually no lower end wear from that.
The clips breaking or dirty airfilter pulling in happens way to much to the 7.3's not owned by guys that are paying attention. Or trucks that go to less than stellar quickie lube places
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #14 of 24 (permalink) Old 07-28-2017, 06:10 AM Thread Starter
Whiskyb's Avatar
Thanks guys, and yes Jimmie I agree. Probably operated by a employee who just did not care as it was not his. Regardless. its mine now and I want my truck back on the road so I can go camping with my very patient wife
Whiskyb
DP Tuner
Whiskyb is offline
post #15 of 24 (permalink) Old 08-07-2017, 12:49 PM Thread Starter
Whiskyb's Avatar
Ordered the motorcraft rebuild kit from riff raff. Amazing service so far. Received shipping confirmation in under an hour after placing it.
Whiskyb
DP Tuner
Whiskyb is offline
