Engine build - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 24 (permalink) Old 09-23-2017, 12:17 PM Thread Starter
Whiskyb's Avatar
Well its about time for a update and a couple of questions as well. The Ford kit from riff raff has been very good so far. I have also used our forum discount and been receiving parts from Rock Auto on a weekly basis. I just received my new oil pan and next week will be receiving a new timing cover. My old one had some wear in the water pump area so I am going with a new one.
Has anyone ever used the 1" thick crank spacer to install the wear sleeve for the rear main? It seems to be a option. Also does anyone know the bolt size for that spacer as I will not have proper ones until I yank the motor out of my truck to install this one.
Whiskyb
2001 F350 4X4 Super Duty PSD Dually
Almost 400k and still given her
DP Tuner
and guages, DIY air intake, BTM,
Dieselsites trans and coolant filters
Wicked wheel 2 (Gone) , Guzzles billet fpr
Whiskyb is offline
post #17 of 24 (permalink) Old 10-03-2017, 02:59 PM Thread Starter
Whiskyb's Avatar
Starting to look around for a new HPOP. Since I am mostly stock but might play later I am thinking of the Terminator T500 sold through DP-Tuner. It in my price range as well. What are the differences between the 15* and 17* pumps? I have a 99 and a 01 that I can send for rebuilding. preferences? Any other reliable and proven builders that I should look at?
Whiskyb
DP Tuner
Whiskyb is offline
post #18 of 24 (permalink) Old 10-03-2017, 04:01 PM
blue99stroker's Avatar
Joey of terminator is very hard to get ahold of if you have an issue.
I would either get the adrenaline from dieselsite or a stage 1 pump
From Cncfab
The obs and e99 has 15* hpops. swashplate was a little different. The 17* are a higher output.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #19 of 24 (permalink) Old 10-03-2017, 04:46 PM Thread Starter
Whiskyb's Avatar
Thanks for that, when they rebuild them if I were to send a 15 would it come back as a 17
Whiskyb
DP Tuner
Whiskyb is offline
post #20 of 24 (permalink) Old 10-03-2017, 05:29 PM
If you payed for a higher output pump it would come back a 17*.
Anytime. Service is almost as important as parts.
post #21 of 24 (permalink) Old 09-05-2018, 05:58 PM Thread Starter
Whiskyb's Avatar
Another update, I just used the riff raff tool to do my injector cups last night. Had a hard time sending it back today as it is a very nice unit. Did the remove and install on a engine stand in about an hour. Its been a long road since I am doing the body on the truck as well at the same time. All new rockers, both inner and outer as well as cab corners and doors from the south. Sitting bare metal right noe waiting for the SPI epoxy this weekend if all goes right
Whiskyb
DP Tuner
Whiskyb is offline
post #22 of 24 (permalink) Old 09-05-2018, 09:59 PM
She’s goung to be a beauty when you’re done.
The riffraff tool is as good as it gets
post #23 of 24 (permalink) Old 09-07-2018, 04:39 PM Thread Starter
Whiskyb's Avatar
Thanks, this forum has been great for help
Whiskyb
DP Tuner
Whiskyb is offline
post #24 of 24 (permalink) Old 09-08-2018, 02:28 PM
jleedog's Avatar
Following your build. Love what you are doing. Keep up the updates.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
