Engine Mod Help - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-03-2010, 11:18 PM Thread Starter
Engine Mod Help
Im new to the diesel world with a 2000 7.3, it gets used as a work truck towing up to about 16K, but also as a daily driver , to have some fun in also. I was thinking of a DP tuner- 40t-80-100-120-140, with a DIY air filter, a 4" turbo back MBRP exhaust, and a water/meth to help control EGT's temps. how do you think the truck will respond with these mods, and anything else to help power without going into big money. Thanks
thebig450es is offline
post #2 of 3 (permalink) Old 01-04-2010, 12:11 AM
dsroka80504's Avatar
Pretty much what I did, except with different brands. I would recommend the ATS Ported Compressor housing, it will stop your turbo surge from when you tow. You will probably need a new wastegate housing from either Banks or TurboMaster also because with the additional boost the DP will make, the stock one will blow off. I don't know anything about the water/meth so I can't hep you there. Jody can also burn you a decel tune that will act like an exhaust brake using your EBV on your truck which is a really cheap way to get an exhaust brake.
2011 F350, CC, SB, Lariat Ultimate, Chrome Package, 4x4, FX4, White Platinum, 6.7L (SOLD)
2001 F-250 CC Lariat, LB, 4x4. 205K and Traded in
1996 F-250 XLT Regular Cab, 4x4, 187K. Bartered for construction work.
2010 Cougar 32RLB 5th Wheel - Traded in 1/22/11
2011 Road Warrior 30C Titanium Edition (SOLD)
dsroka80504 is offline
post #3 of 3 (permalink) Old 01-04-2010, 11:19 AM
Feedback Score: 3 reviews
A WW will stop surge 90% of the time, get a genuine Tymar kit. TW tunes.
caryt is offline
