exhaust stack mounting ? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 12-01-2012, 02:15 PM Thread Starter
Jgravel's Avatar
Im thinking of adding a stack to my exhaust system. Im curious as to how others are supporting a stack thru the bed. I'm thinking a mounting point in the bed to support the stack, with a piece of flex exhaust to compensate for frame/body flex. Any input is appreciated
-85 F350, 6.9, 4 speed, dually, dump
Soup bowl mod, Slightly turned up IP, 3-3.5 straight exhaust, manual GP, dual optima yellow tops, F450 solid front axle
-99 F350, 7.3, 6 speed, ext cab 6' bed, SRW
4" straight exhaust to 5" stack, cold air intake, turbo master, TS chip, XDP X wheel, AIH delete, Foil delete, 2" leveling kit
Jgravel is offline
post #2 of 2 (permalink) Old 12-01-2012, 04:23 PM
RocDoc's Avatar
Stacks are dumb for street use.
2000 XLT, 4x4, SC, SB, Snugtop Shell, 4" lift
4" MBRP, ISS Pro Gauges, 80hp DP-Tuner flash,
AIS w/Zoodad, 315-16's, AIH delte (boost sensor port), coolant filter.
Bangin' stereo, Randy Ellis light bar, 4-130w lights, Airbag
RocDoc is offline
