F6 or not? - Diesel Forum - TheDieselStop.com
 2Likes
post #1 of 16 (permalink) Old 10-07-2016, 05:28 PM Thread Starter
F6 or not?
I'm looking seriously at DP's F6 chip. Don't know who I talked with @ DP yesterday but didn't get satisfactory answer on mounting the "Switcher". I have 7 gauges in my '02 SD, 3 on top of dash, 3 in a pod below and an X-Monitor on the pillar. Sounds as tho the Switcher, required for the F5 or F6 chip needs to be mounted in a gauge pod. If so, my gauge pods are all spoken for. Can someone who has an F5 or F6 installed enlighten me a bit? Would appreciate seeing pics of same in a real truck. A simple rotary switch would make me happy but DP doesn't have that option. Thanks for ideas & help ... this is a great forum.
Big RED 2002 F-250 Lariat Supercab long bed-4x4 with auto lock hubs (they work GREAT & I love 'em), 4R100-26 row Trans Cooler-EGT both Manifolds-DP F6 chip with 7 tunes- GAUGES: Trans temp, Coolant temp, Oil Pressure, Engine oil temp (REAL ones), Boost, 2 EGTs, Fuel pressure, etc, etc.
'The most terrifying words in the English language are: I'm from the government and I'm here to help. - Ronald Reagan
* "You can observe a lot by just watching". - Yogi Berra
! "In theory there is no difference between theory and practice. In practice there is". - Yogi Berra
xblowhard is offline
post #2 of 16 (permalink) Old 10-07-2016, 05:40 PM
79jasper's Avatar
But they do. @[email protected]
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #3 of 16 (permalink) Old 10-07-2016, 08:26 PM
RT
RT's Avatar
You have multiple options for the switcher. You can get a gauge mounted switcher like I have. You can get a small, rectangular surface mounted switcher that you can put anywhere on your dash, or you can get a rotary switcher that you could mount behind a panel with the dial on the outside. They all work with the F5 and F6.
Here's the full page of selections - https://www.dp-tuner.com/ford-powers...isc-1.html?p=1
rotary switch - https://www.dp-tuner.com/ford-powers...-switcher.html
surface mount - https://www.dp-tuner.com/ford-powers...cher-blue.html
That link is to the blue color, although there are many other choices.
You're only regret is going to be that you didn't get this sooner. The DP-Tuner is going to wake up the beast that has been hiding under your hood.
RT is online now
post #4 of 16 (permalink) Old 10-07-2016, 10:42 PM Thread Starter
RT, thanks for the info. That settles it for me, I think. The guy I talked with yesterday at DP must be a new employee. He knew almost nothing about the chip or options. I'll try to talk to Justin Monday and get the F6 headed out here. By the way, I made a small effort to uncover my computer code but the cover didn't want to slide off after removing the 2 screws on the inside of the cab. The cover slips back 1/4" and stops. Can't see that it's hanging up on anything. Didn't think it was necessary to unhook under the hood just to look for the PCM code. Can you suggest anything? Force? Makes me nervous. I read somewhere that on '02s only the inside screws needed to be removed to uncover the PCM and see the code.
post #5 of 16 (permalink) Old 10-07-2016, 10:45 PM
79jasper's Avatar
Use a inspection mirror and flashlight.
79jasper is offline
post #6 of 16 (permalink) Old 10-07-2016, 11:22 PM
blue99stroker's Avatar
Best chip for the price is the hydra.
It's 375$ from most vendors. It mounts easily on the dash with a piece of Velcro that's provided.
You get access to a library of php tunes. You can load up to 15 tunes onto it. All included in the cost of the chip. No extra cost for tunes.
The list of vendors that tune for the hydra is long. If you ever want custom tunes for injectors or other mods everyone tunes for it.
Or if you only plan on running basic mods go with a ts chip for 250 from a few vendors. They come with php custom tunes as well.
It's up to you of course. But... I would save yourself 200-400 dollars and go with the hydra or ts
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #7 of 16 (permalink) Old 10-08-2016, 05:04 AM
jleedog's Avatar
You can look on youtube to see how the installation of your DP tuner is done. I also have an 02, not sure what your problem is taking the PCM out mine was rather easy. Do you have the bolt on the connector under the hood all the way out?
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #8 of 16 (permalink) Old 10-08-2016, 06:07 AM
The plastic housing catches on one of the brackets. I believe it's top outside where it hits so nearly impossible to see. Pulling it hard enough to get past it makes me nervous every time also.
Gator
2001 F-450 4x4 XL CrewCab Flatbed (Loved this truck, sold it to a friend and he says he will never sell it!)
2000 F-350 4x4 Lariat LE CrewCab Flatbed - 325k miles all stock, needs some maintenance but still going strong! (My daily driver)
1999.5 F-350 XLT CCSB - 335k all stock (now a parts truck)
2002 F250 CCSB 4x4 previous owner threw a lot of aftermarket money at it with little gain, added a TS6 w/Gearhead tunes. (Brother's daily driver)
2001 F350 CCLB - 180k all stock (Sister in laws daily driver)
2005 Ford Expedition (Wife's daily driver)
Wife is patiently waiting for the right Diesel 4x4 Ecursion to show up....
And many other non-Ford vehicles...
Gator5713 is offline
post #9 of 16 (permalink) Old 10-08-2016, 09:04 AM Thread Starter
Thanks guys, for your info & help. I'm gonna have another go at pulling the cover off the PCM today to get the code. Don't want to pull the computer out & disable the truck 'till I have the chip & am ready to install it.
post #10 of 16 (permalink) Old 10-08-2016, 09:16 AM
RT
RT's Avatar
Remember, the only difference between the F5 and the F6 is the ability to load tunes on your own as opposed to sending the chip back. I got the F6 for that reason, however the tunes I got are so absolutely perfect that I've never needed more than I started with. I'd get he 60 econo for highway driving, the 80 econo for city driving and mild loads (like up to a ton of dirt or rock in the bed), and a tow tune for when you are pulling a loaded trailer. I got a performance tune, but I've only used it once. I don't need those kind of horsies for utility functions, but you may enjoy eating Mustangs with your 8500 pound steel brick.
RT is online now
post #11 of 16 (permalink) Old 10-08-2016, 01:07 PM Thread Starter
RT, you're messin' with my brain! I'm torn...to save a good sized chunk of change or opt for the versatility & possibility of making it easier to change my mind down the road. I'm getting too old to enjoy crawling around under the dash any more. But I can hardly stand the thought of letting someone else monkey around with my baby. Still haven't got the cover off the PCM to read the code. Gotta get out there & yank on it again. I do like the "Try before you buy" option on the F6.
post #12 of 16 (permalink) Old 10-08-2016, 04:55 PM Thread Starter
Cool
Right on! I was afraid of injuring something (my WALLET?) SO I disconnected the cable under the hood. There is a lip on the plastic cover that hooks behind the metal bracket that supports the PCM. I undid the lower nut on the metal bracket where it attaches to the firewall, moved the bracket toward the parking brake and with a bit of wiggle/force, out it came! The nut that holds the topside of the metal bracket looks impossible to get to, but pushing the bottom part over does it. I now have my PCM out to admire and fiddle with. Not putting it back in till I have a chip to stick on it if my sweet wife will let me ride around in her Escape. My PCM code is Q L J 2 ... does anyone care? For 84 years my motto has been: "SOMETIMES YOU HAVE TO BREAK SOMETHING TO LEARN HOW TO FIX IT". So far, I haven't had to break anything on this project.... Praise the Lord!
Thanks to all for holding my hand while this was going on. I'll add to this post if anything exciting happens.
post #13 of 16 (permalink) Old 10-17-2016, 09:49 PM Thread Starter
Got my F6 chip with 5 tunes 4 days ago. Installed it over the weekend and it's still in the "testing" stage but it's looking and feeling pretty good. I mounted the "Switcher" flush in the dash, right of steering column, just below the speedo. That worked out well & looks good to me. I'm happy.
post #14 of 16 (permalink) Old 10-19-2016, 06:43 PM
Hearing this, I am thinking you may have called some other company instead of us. This actually happens all the time. We have dealers that have similar company names to ours. The reason I say this is because it is only Jody (owner), Diane (owner), and myself over here at DP-Tuner. All of us have a lot of knowledge on our products and would have been able to answer your questions, to your satisfaction.
If in fact you did call us, I apologize on our behalf if we weren't able to get you the answers you were looking for.
Somehow, I never got notification of this mention. Hense, why I am just now seeing and responding to this thread.
Thanks though Jasper.
Again, I am thinking you may have called one of our dealers. If it was actually us, I do apologize.
Usually what the cover gets hung up on is the cable located above the PCM. Sometimes you have to move the cable, or wiggle the PCM/case at a different angle to get it out.
Glad you are enjoying it. Sorry for the delay in response to this thread. I did not get notification of Jasper's mention, as I said above.
If you ever have any questions or concerns, don't hesitate to contact me direct. All of my contact info should be in my sig. You can get a hold of me by PM, e-mail, or phone. I would be happy to help you out.
79jasper and xblowhard like this.
post #15 of 16 (permalink) Old 10-19-2016, 09:56 PM Thread Starter
Hey Justin, thanks for clearing the mis-information up a bit. You and I talked by phone a couple of times since my remarks about a person purportedly from DP. My conversations with that person were a bit unsettling and almost sent me in another direction. But after speaking with you directly, I felt reassured to the point that I went for the F6 chip with Bluetooth. The installation was completed 4 days ago and my smile grows wider every day. The 100 HP Tune is awesome! Justin & Jody ROCK!
Emmitt
