Finally Did My CCV Bypass Mod - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 22 (permalink) Old 02-28-2005, 10:57 PM
My Photos: (19)
Re: Finally Did My CCV Bypass Mod
Gary-
as long as the end of the hose is not clogged with ice or snow, you should be OK.
redrocket
*SOLD* 2001 F-250,Toreador red,ext cab,4x4,BB turbo/1.15 housing,Mini Me's,pushrods,headstuds,AirDog,ATS Stage 5 tranny,DI headers,Hypermax Tapercore,471hp/lost the tq(Dynojet)
*NEW* 2004.5 Dodge Cummins,LB,QC,4x4,Laramie
redrocket is offline
post #17 of 22 (permalink) Old 03-01-2005, 05:23 AM
What about using a tranny cooler type of condenser for the most condensing affect. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 psd CC SB 4x4,
This...That...And-The-Other...
OLD Powerstroke 7.3l
620.8HP/1157.9TQ Dunbar's Dyno 5/26/07
New Cummins 5.9l 12v Conversion.
sno_cat is offline
post #18 of 22 (permalink) Old 03-01-2005, 07:00 PM
Is the factory set up for venting the CCV into the turbo inlet causing any real problems for the engine or performance of the truck?
I would like some advise on this issue.
2001 F250 SD, 4x4, Crew Cab Lariat,Turbo Temp Monitor, EGT, Boost, & Tranny Gauge, Mobil 1 ATF, Diablo Sport Shift Valve, Banks Six Gun Tuner, Banks Monster Exhaust, Banks Big Head Actuator, Banks Transcommand, Tru-Cool Aux Trans fluid cooler, MagHytec Trans Cover, EBP Valve Delete, AIH Plug, DR 2" mini spring level kit, Bilstein Shocks, Performance
Friction Rotors and Z-rated pads, MTX 285's.
Middleburg, Florida (Just South of Jacksonville)
dmason57 is offline
post #19 of 22 (permalink) Old 03-01-2005, 07:14 PM
fordmastertech's Avatar
It can if the air charge cooler gets full of oil. The oil in the intake system will also soften the rubber hoses and make them leak causing boost to be lost.
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #20 of 22 (permalink) Old 03-01-2005, 08:06 PM
Hi Guys
Any one ever hear or this oil catching fire in the turbo , I know the turbos can get pretty hot and could possibly bring that oil to combust , I have heard of this happening to big rigs.
I just put my by-pass last weekend and 500mi's later not a drop of oil in my "T" , I just ordered a 4" stainless thin wall piece of pipe to replace my plasic intake connector.
Later
Greg
2001 F-350 SRW SCB 4x4 Lariat , Toreador red , Diesel , 6" Donahoe , 325/50/r22 , Alcoa mini floats , Texas Outfitter front and back pipe bumpers , AIC , Lund fast back , airlift , rhino liner , Homemade Tymar with 4" stainless , Ispro gauges , open air CCV out the back .
Greguw is offline
post #21 of 22 (permalink) Old 03-01-2005, 08:25 PM
CHPMustang's Avatar
The CCV oil vapors going through the turbo assembly is on the cool side which to my knowledge no flash fires have started.
Another negative result of CCV oil residue coating the passages of the intercooler can also reduce it's cooling ability especially when the hot summer months is upon us.
2002 Ford Excursion 7.3L 4x4 XLT
, 6.0L cooler,
Magnaflow 4"- FRX CVD Valving - FRX Crossover - HPX
Bilstein 5100's - AFE Stage 2 - Adrenaline HPOP
LandYot's
CHPMustang is offline
post #22 of 22 (permalink) Old 03-01-2005, 09:09 PM
Hmmm... I'm not sure whether the oil in the CC gas is truly evaporated (a vapor), or if it is a mist of tiny droplets (or most likely a combination of both). If it is truly a vapor, the cooling the vapor will cause condensation, but if it is mostly mist, the cooling would have little effect. Most of the mods I have seen, including Racor's system, include "coalescing media" or something with a lot of surface area for the gas to pass through, and the mist droplets to collect on, join into bigger droplets, drain, etc. One problem with a tranny cooler would be whether it was designed to drain any condensate to a sump for collection. Given that they are designed to flow fluid, not gasses, I doubt that was a design goal for them. Also, given that the oily residue makes it past the turbo, where the gas is heated, and yet still collects on the boots, etc., I would think that most of it is mist, not vapor.
Interesting idea though...
Andy
2002 F250 XLT PSD Auto CC SB 2WD. Owned since new.
265/75R16E Bridgestone Dueler AT Revos
Ford AIS Intake w/ Motorcraft Element
Optima 34/78 Red Top Batteries
Fleetguard LF9027 Venturi Oil Filter
22" Wiper Blades
BigJakeJ1s is offline
