Fuel pressure gauge install - Diesel Forum - TheDieselStop.com
 3Likes
post #1 of 17 (permalink) Old 03-19-2019, 08:48 PM Thread Starter
jleedog's Avatar
Going to be adding a fuel pressure gauge to the truck soon. Isspro installation manual recommends a "snubber" to be used before the pressure sending unit. Do I have to add this part? Anyone not using it? Will it hurt the gauge or cause it to be to erratic. Any input is appreciated.
From the Install manual: Install Snubber kit R78828 with the 7/16 SAE O-ring adaptor threaded into the test port on the fuel bowl.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #2 of 17 (permalink) Old 03-19-2019, 08:57 PM
2000F250-7.3's Avatar
The snubber is for fuel pressure spikes keeps from damaging the sender . I donít run one on my 7.3 and have had a gauge on it for ten years and only replaced one gauge sender do to damaging it wile working on the engine.
jleedog likes this.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #3 of 17 (permalink) Old 03-19-2019, 09:13 PM
RT
RT's Avatar
Same here. Over 100k on my ISSPRO sending unit attached straight to the back of the fuel bowl. Never had a problem.
jleedog likes this.
RT is offline
post #4 of 17 (permalink) Old 03-19-2019, 09:16 PM Thread Starter
jleedog's Avatar
Did you guys both mount the sender directly to the bowl, or a remote location because of vibration?
jleedog is offline
post #5 of 17 (permalink) Old 03-19-2019, 10:30 PM
RT
RT's Avatar
Mine is directly to the bowl with this adapter- http://www.dieselorings.com/1999-200...-1-8-fnpt.html
RT is offline
post #6 of 17 (permalink) Old 03-21-2019, 09:14 PM Thread Starter
jleedog's Avatar
Help please, Finished install today with the pressure sending unit installed on the passenger side port of the fuel bowl. Fired the truck up and it reads 25 psi steady. Have yet to drive it yet, the truck runs fine. Shouldn't I have at least 40 PSI at idle? Any suggestions? I have a new Bosch pump that I have been meaning to install. Does the sending unit need to purge out the air by driving? Or is it possible I have a bad gauge/ sending unit. I figure Isspro would be a good brand.
jleedog is offline
post #7 of 17 (permalink) Old 03-22-2019, 08:11 AM
RT
RT's Avatar
ISSPRO is a great brand. Air clears out almost instantly since fuel goes past the regulator and back to the tank. You either have a supply issue (pump / clogged filter in the tank) or a regulator with a weak spring or bad seat. See what happens when you accelerate aggressively.
RT is offline
post #8 of 17 (permalink) Old 03-22-2019, 09:59 PM Thread Starter
jleedog's Avatar
OK spoke with an isspro tech today and we did some tests with a voltmeter with the gauge and sending unit. Everything checked out fine. The Tech told me that he has an pre 99 7.3l that has the same pressure when running. He suggested a new fuel pump or rebuilding the fuel pressure regulator. So im going to start with a new fuel pump and see what happens. Will update when I know something.
jleedog is offline
post #9 of 17 (permalink) Old 03-23-2019, 05:18 PM
RT
RT's Avatar
You should be able to narrow it down with the test I suggested. If it is a supply issue, when you accelerate, the pressure will plummet. If it is a regulator issue, it won't change.
RT is offline
post #10 of 17 (permalink) Old 03-24-2019, 11:46 AM Thread Starter
jleedog's Avatar
So I installed a new Bosch fuel pump and I gained 5psi on the gauge. 30psi and it drops 3-4 psi when I accelerate heavy. So I ordered a fuel pressure rebuild kit and housing from dieselorings. Thank you for your help. Will update soon
jleedog is offline
post #11 of 17 (permalink) Old 03-24-2019, 11:51 AM
RT
RT's Avatar
I think youíre on the right track. Be uber careful with the regulator housing- the threads snap off easily. Bob has a billet replacement if that happens.
RT is offline
post #12 of 17 (permalink) Old 03-24-2019, 11:42 PM Thread Starter
jleedog's Avatar
In anticipation of snapping off the fitting, I ordered the new billet housing and replacement nut and bushing as we as the rebuild kit. Wondering what spring I should put in when I do the work?
jleedog is offline
post #13 of 17 (permalink) Old 03-25-2019, 07:46 AM
RT
RT's Avatar
The silver should be fine. 60 psi is your ideal pressure. Iíve never seen a benefit of going higher. Just more work for the pump.
jleedog likes this.
RT is offline
post #14 of 17 (permalink) Old 04-01-2019, 01:17 PM Thread Starter
jleedog's Avatar
Ok, so I rebuilt the entire fuel bowl (thanks Dieselorings.com) Including the new housing for the pressure regulator and new poppet and seat.. New fuel filter (thanks Amazon). Fired up the truck and I now have 75psi at idle. WOW! I did not take RTs advise and use the silver spring. I used the gold one. I am planning on upgrading injectors soon, and I wonder if I might need that extra fuel pressure for them. Should I keep it at 75psi or should I take RTs advise and put the silver spring in and drop it down a few PSI to save wear and tear on the pump. Isspro gauge seems very stable even at WOT. Pressure got as high as 78PSI on the gauge when test driving. I swear the truck seems a bit more responsive now and may have a few more HP. I cant wait to tow and see if will improve my EGT.
jleedog is offline
post #15 of 17 (permalink) Old 04-03-2019, 06:15 AM
Take RT's advice.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 254,500 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
Similar Threads
Useful data about DIESEL fuel airfooter Bio-Diesel and Alternative Fuels 7 02-16-2012 06:54 AM
New little secrets thru 07/30/05 Larry M E-Series Vans 18 01-28-2010 03:14 PM
Truck making noise then died at dealership jays2003 6.4L Power Stroke Engine and Drivetrain 90 12-15-2009 02:46 PM
Filled with Gas instead of Diesel myron 6.0L Power Stroke Engine and Drivetrain 14 08-04-2008 03:57 PM
