Gettin back to my new chip - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-27-2005, 05:31 PM Thread Starter
My Photos: (5)
Ok...now that it seems like I have this new forum thing figgered out...I'll continue on my new chip.
With the new chip...the truck just flat out scoots! [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img] I was running in the 75hp position...and it felt just as strong as the 110hp position of my old SCMT.
Shifting with my MonsterBox tranny was very...very nice. They were quick and firm...no harshness in them whatsoever. When I laid on the go peddle...there was a little haze...but not much. Again...this is only the 75hp position. My 3-4 shift flare is gone...and TC lockup seems to be better.
But...for the first time I set my SES light. I never did that with my SCMT. After about 10 minutes...the light goes away. I got on the isolated road that my work is on and nailed it to see if it was an overboost. Boost never got above 25 pounds...and the light stayed off until she shifted into 4th. She just kept pullin and pullin...then the SES light triggered. My hunch is that it has something to do with my early 99 HPOP. Not sure if the chip can be reburned to deal with the SES issue or not.
And to the person that asked before the big archive...its a TS 6 pos chip (no start/stock/hi idle/50hp/75hp/125hp). I will prob wait until it warms up some before I play with the 125hp position. Cold weather is hard enough on the truck...and I'm not in the mood to overstress stuff in the cold weather.
Dave
'early 99 F250 XLT CC 4x4 PSD PMT1 PCM, FT Monsterbox :Thumbup: , Autometer Cobalt's, DP Tuner F5 chip, MBRP 4" turbo back cool duals with ITP 5" SS tips, Stealth HPOP, aFe intake with pg7 filter, Baldwin bypass filtration for oil, coolant & tranny, Excursion headlights, corners & heated TT mirrors, painted door handles & cowl, Lariat rims, Hutch's fuel tank mods, 'Pooned with Dahl 100 fuel filter, ITP's Regulated Return fuel mod, HX mod, 203* thermostat, tru-cool max tranny cooler, Retrax cover, Westin SS nerf bars and bull bar, pulling an '04 Wildcat 31QBH 5'er.
10/1/06 [color:"Red"]333 HP/693 TQ[/color] on Dunbar's dyno.
of my truck,
4cstr is offline
post #2 of 8 (permalink) Old 02-27-2005, 05:45 PM
Send a message via AIM to Bobcat698
Re: Gettin back to my new chip
Glad to hear the shifting is working with the MONSTERBOX!
If you still have the Superchips, pull the chip and see if you can read the code.. If you like.
Bobcat698 is offline
post #3 of 8 (permalink) Old 02-27-2005, 06:09 PM Thread Starter
My Photos: (5)
I still have the SCMT...it gets sent off tomorrow.
Do I have to pull the chip to pull codes? I was under the impression that I didn't have to.
Dave
of my truck,
4cstr is offline
post #4 of 8 (permalink) Old 02-27-2005, 07:17 PM
My Photos: (21)
Pull the code(s) for sure...
You will more than likely see: [injector pressure too high/low]...I get that occasionally when I'm towing and pulling a grade.
Cheers
1999 F-250 Power-Stroke
Crew Cab Shortbox Lariat 4X4
Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned by Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
2006 Jeep Liberty Sport CRD 4X4...
Tough_Guy is offline
post #5 of 8 (permalink) Old 02-27-2005, 07:19 PM
Try it without pulling the chip & see what happens..
Maybe it will work..
post #6 of 8 (permalink) Old 02-27-2005, 07:38 PM
My Evolution cleared the KAM code after installing my chip. I haven't gotten any others yet...other than the Air Intake Heater one. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Remember, this is the internet, where everyone's a diesel mechanic and has 500+hp/1000+lb/ft under the hood! Read up, form your own opinions, then do your own real-world testing!
'01 PSD F-250 XLT SC LB 2WD 6SPD 3.73LS, Alliant AC's,ARP Studs, Stealth Dual HPOPs, GTP38R, Forged Rods balanced, Fluidampr, South Bend CON OFE, 6.0L Intercooler, Volant Intake, 4" SS MBRP Exhaust, A-Pillar mounted Lunar Series Boost/Pyro Gauges,4 pos. Chip with Stealth burns from Twildman, playing with Minotaur Tuning software too, heated Racor 900FH 2 micron, Hutch mods, harpoon mod, DIY Regulated Return, 203 T-stat, coolant filter, AIH gone, CCV Mod, boost pressure relief valve, 100 gallon tank/toolbox combo...AutoEnginuity diagnostics for all Domestics
roosterdiesel is offline
post #7 of 8 (permalink) Old 02-27-2005, 07:44 PM
I agree with Tough Guy,it will probably be that the injector control pressure is high/low.
I will get the same code if I'm really standing on it in the 125 mode and usually it (ses light) flashes on a shift.
Howling
No Limit Diesel Performance
2006 Dodge 4x4 CTD/48re QC sport
2001 F350 4X4 PSD AFE Stage 2,TS PMT1,BB Turbo 1.15 Exhaust Housing,5" Ceramic Coated Exhaust,
Gauges,FASS Fuel,ect.... -Sold
2001 Chevy Dmax regular cab sled puller/drag racer
Best et to date 10.85 at 123+ 5900lbs.+
Howling is offline
post #8 of 8 (permalink) Old 02-28-2005, 11:59 AM Thread Starter
My Photos: (5)
I was able to pull the codes using the SCMT. I had 2 codes...P0603 and P0640. The one was from having the batteries disconnected while installing the chip. The other is the air intake heater code. There were no other codes.
Does the IPR too high/low code stay...or does it go away? My SCMT couldn't clear the P0640 code...even tho I tried 3 times.
Dave
of my truck,
4cstr is offline
