got my dp tuner - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-25-2011, 09:03 PM Thread Starter
907stroker's Avatar
got my dp tuner
HOLLY CRAP EVERYONE WAS RIGHT, its a day and night difference. got my f5 today with no start, stock, 80 tow, 80 ecco, 100 performance, and lope . the differance is so amazing. now when i shift its so much smoother. and so much more responsive. deffinatly woke up the beast within!
thank you so much everyone who encouraged me to get the f5
and jody and Diane for making such a great product.
on another note, how much of a difference is there between 120 and 140. im thinking of sending back to take the 100 off and switch for one of those
99 f250 6 speed, pretty much stock, extra heavy suspension, dp tuner f5, intake
907stroker is offline
post #2 of 8 (permalink) Old 02-25-2011, 11:22 PM
lariat 7.3's Avatar
Send a message via AIM to lariat 7.3
you wont even notice much of a difference between the 80 economy and the 120 race. i have both of them. they dont recommend the 140 without supporting mods like a better HPOP because the stock pump cant keep up the the injection pressures the chip is asking for, so you may actually see less performance in the 140 than in the 100
2000 f 250 4x4. ccsb
just hit 218,000
38R with Turbo Master
238/80% hybrids
Riff Raff FRx
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
lariat 7.3 is offline
post #3 of 8 (permalink) Old 02-26-2011, 12:09 AM
Would the DP tuner on the 100hp tune make the 110 tune on my superchip look like a slug?
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
[SIGPIC][/SIGPIC]
browningbuck225 is offline
post #4 of 8 (permalink) Old 02-26-2011, 01:00 AM
lariat 7.3's Avatar
idk what the horse power rating was on the superchips that came with my truck was, i always ran it on the high performance setting its the old style black one. My 80 econo makes that seem like a slug lol
just hit 218,000
238/80% hybrids
Riff Raff FRx
remote start.
AIH cut off
bypass oil system
running on WMO!
post #5 of 8 (permalink) Old 02-26-2011, 01:17 AM
yea the Max Micro tuner. That's what I have
[SIGPIC][/SIGPIC]
post #6 of 8 (permalink) Old 02-26-2011, 09:55 AM
99SD250's Avatar
my 120 and 140 settings dont seem much different i use my 140 setting for smoking out tail gaters !!
99.5 F-250 psd crew cab short bed, 235,000 miles all orignal motor minus 2 oil pans, 6 inch Bds lift, 2 inch shackles, 38in 14.50 Toyo M/T, 16x10 M/T classic II rim, warn lock outs, dyna trac wheel bearing kit, Duel BDS Duel steering stablizers , Superlift Shocks, Dp tuner 80,120,140, Bully dog 4 inch turbo back straight piped , 5in tip, Zoodad mod, DIY intake, wicked wheel, Auto Meter sport comps, AiH Plug, Billet torque converter, Sonnax/Tricum Kit
99SD250 is offline
post #7 of 8 (permalink) Old 02-26-2011, 05:41 PM
my superchip tuner on 100 performance seemed like it smoked alot, but lacked any significant power increase. got the 80econo tune and it will run circles around the superchip. the truck is just amazing with the dp tuner and it's a early 99. you guys with the later trucks must really be incredible!!!!
During a conversation with James at DP Tuner he pointed out they are still learning and developing tunes for the 7.3 8yrs after production stopped. Most of the other big manufacturers stopped developing new tunes for the 7.3 shortly after the 6.0 was introduced.
tinkerr is offline
post #8 of 8 (permalink) Old 02-26-2011, 05:49 PM
mwe-maxxowner's Avatar
Send a message via AIM to mwe-maxxowner
If you already have it, I wouldn't bother with shipping back and such to switch to the 140. Too much aggravation to ship back and forth, and you'd most likely not see a big enough difference.. I don't have a 120 tune, just a 100 then 140. I can feel a difference between the 100 and the 140, but it's not huge. It's not enough for it to seem worth it to me to ship back and forth to go from the 100 to the 140.
Since I got it to start with, I enjoy it and am glad to have it, but after experiencing the two, I'd definitely not pull the chip and send it in to add a 140 if you already have a 100. If you had an f-6, I'd say when a spare 45 bucks is in hand, sure why not add it, but definitely not worth pulling the chip. Enjoy the tunes! It's a surprising difference, that's for sure!
87 f250 4wd LB ex cab 460 bored .60 edelbrock intake, towing cam glasspacks-6 mpg 8 on good day- my pride & joy once towed my '85 j-co j-crane 28' 5er
99 F250 7.3(engine stamped june of '99) 250K white ex cab lb, 2wd
jl audio slash 4ch amp, jl 8" sub, focal components front, infinity coax rear, 10 disc changer
-tymar intake, no muff
-bullydog egt, autometer boost
-f5 chip w/80t, 80e, 60t, 100, 140 extreme(140 is amazing!)
Garrett 38r
Chrome fender trim, 265 nitto terra graps, nerf bars, billet grille, '06 headlights, chrome door handles, louvered 5er tailgate
mwe-maxxowner is offline
