Had Pac Brake installed , not working - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 06-14-2019, 11:38 PM Thread Starter
I had a pac brake installed on my 03 7.3 auto transmission, installers cannot get brake to engage when driving, compressor runs, with key on switch turned on and lights up, you can here valve go through its check sequence, but when you drive nothing happens, have a red light on switch never turns orange and no sound or evidence the valve closed. Its Friday night and we are headed out supposedly Sunday, any thoughts ideas would be appreciated, thanks
Firedad207 is offline
post #2 of 5 (permalink) Old 06-15-2019, 08:35 AM
From my experience with these exhaust brakes, it’s probably the switch at the throttle not engaging
Buffalohead1 is offline
post #3 of 5 (permalink) Old 06-15-2019, 10:08 AM Thread Starter
Thanks , how do I check the throttle switch ?
post #4 of 5 (permalink) Old 06-15-2019, 08:49 PM
It’s a micro switch bolted to the side of the accelerator pedal that activates when completely off the throttle. Disconnect the wires and test for continuity when the switch should be closed. I sometimes skip my foot off the pedal to slap the switch into activation.
post #5 of 5 (permalink) Old 06-17-2019, 02:39 PM
If the compressor is running check to see if the cylinder cycles on the pac brake. Check for any airleaks too.
