Has anyone done a '05-'07 axle conversion in an '99-'04? - Page 5 - Diesel Forum - TheDieselStop.com
 2Likes
post #61 of 72 (permalink) Old 03-23-2017, 08:03 AM
Wobblin-Goblin's Avatar
Excuse me if this is a dumb question, but the pic of the "old" axle on the trailer looks to have drum brakes. Don't all Super Duties have disc brakes front and rear?
Also, interesting thread. Good work by all.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1994 Dodge 3500 SLT Dually 5.9L Cummins NV4500 5spd US Gear "splitter" Exhaust brake 4x4
RETIRED: 1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
NRA Life member
Wobblin-Goblin is offline
post #62 of 72 (permalink) Old 03-23-2017, 10:03 AM
Phil G.'s Avatar
Those shoes are the park brake shoes, the rotor fits over top of them.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog - *Updated 8/18 with Edge CTS2 install click here =>*:
Phil G. is offline
post #63 of 72 (permalink) Old 03-23-2017, 12:12 PM
Steven,
I'm not sure about the brake lines and power steering lines. However, when changing from front leaf suspension to front coil suspension, I have read a few threads on forums mentioning the need to change the power steering gear box from 1999 - 2004 to the 2005 - 2007. I looked on Ford parts website ( fordparts.com ) and it shows different part numbers and weight, but photos and dimensions are the same. I would contact Red Head Steering Gears in Auburn Washington. They are the experts. Evidently they developed a proprietary process to build bullet proof steering gear boxes. Ask them if the steering gear boxes are different between the 1999 - 2004 and 2005 - 2007 model years. I would also search the internet for aftermarket hoses. You might check with DieselSite in Florida. For brake lines...not sure about that. For brake lines, I would recommend Crown performance.
This thread caught my eye because I have thought about building a 2002 Ford F350 Crew Cab 4WD.....setting the cab, front clip, bed along with 7.3L engine and 4R100 transmission onto a 2005 - 2006 chassis, frame, and suspension...and installing a Carli 4.5 inch suspension system. I previously owned a 2002 Ford F350 Crew Cab 4WD SRW ( LB - 172 ) and I think it had just rear anti-lock brakes...although I might be mistaken. I now have a 2006 Ford F350 Crew Cab 4WD SRW ( LB - 172 ) and it has front and rear anti-lock brakes. This truck has all the parts and upgrades offered by Bullet Proof Diesel. It also has a BTS ( Brian's Truck Shop ) built 5R110. It would be interesting to learn and obtain information about converting rear anti-lock brakes to 4 wheel anti-lock brakes. No doubt there are threads discussing this change.
2Colt45s is offline
post #64 of 72 (permalink) Old 03-28-2017, 07:22 PM
Anyone who's done this conversion, what radius arm brackets did you use to mount the rear of the arms to the frame?
I've got a 2007 4x4 front axle to put on my 2x4 Excursion and would like to use my original radius arm mounting brackets from my twin I beam front suspension. That would save me $400-$500.
Or were you forced to use the newer radius arm mounting brackets?
2001 Excursion XLT 7.3L 2x4 205K
DPTuner, Air Springs, F-350 rear springs, 5R100 TC, John Woods engine/trans spacer, RedHead steering gearbox, Hellwig rear sway bar, Bilstein shocks
2010 Jayco Eagle
absolutezero273c is offline
post #65 of 72 (permalink) Old 08-30-2017, 06:37 PM
great write up gentlemen!!! I have pondered this process for years... now I have full confidence in doing this task.
Jason Berube is offline
post #66 of 72 (permalink) Old 02-12-2018, 11:50 PM
Originally Posted by Steven Barnes View Post
I'm going to be doing the swap in the near future I have almost everything but before I go into it I want to make sure I'm running the correct brake lines also what Power steering line needs to be replaced I've heard the return and the pressure so I'm not really sure and what size hardware is required for the new power steering box
New guy bumping this thread instead of starting a new one. Same questions as Steven Barnes...
Can anyone confirm the metric size and length of the bolts for the 05+ steering box on the 99-04 frame?
And do I need the pressure or return line off an 05+ truck?
Thanks!
96GTS is offline
post #67 of 72 (permalink) Old 02-13-2018, 08:34 AM
Zrtman's Avatar
I know for sure it is the high pressure line that goes from Hydroboost to the steering box that needs to be changed to 2005 hose.
I do not remember the bolt size- it has been awhile since I did the swap. If you look at my pics I went with a slightly longer bolt than the 99-02 and I believe it was 2mm larger diameter.
***ALSO TO RETAIN ABS***
I used the original 2002 rear sensor and installed it on the 2007 rear axle.
I had to swap the abs sensors in front axle to 2002 4WD senors. Apparently 2005+ went to a different style ABS. The earlier sensors bolt in. I just moved the 2002 grommets on the abs sensor wire to same position as 2005 wire so I could follow same wire routing and keep it tucked out of harms way.
ABS works 100%. No ABS light.
2002 F250 Crew Cab Long Bed 7.3 Lariat
2wd to 4wd conversion with 2007 F350 axles/brakes/front coils
AIS, 4" exhaust, F350 rear blocks, Front leveling springs, Drop radius & track arm brackets, Bilstein 5100 shocks, LT295/60-20 Nitto Trail Grappler M/T on factory KR wheels
Zrtman is offline
post #68 of 72 (permalink) Old 02-13-2018, 07:56 PM
CAREYBO's Avatar
Switching from leaf to coil is way worth the effort!
Like night and day difference and well worth it. Anyone who tells you otherwise, doesn’t have a clue what they are talking about.
CAREYBO is offline
post #69 of 72 (permalink) Old 02-26-2018, 01:56 AM
Awesome!! Thanks for the feedback!!
And I've seen another post where the guy welded 1/4" shims to his radius arm brackets. But he was doing this swap on an Excursion. Is that an Excursion frame thing? Are the front of the frames different between the Excursions and the 99-03 Super Dutys? Will I have to do anything like that to my 4wd 2000 F350?? Or will the brackets fit flush against my frame as-is?? Thank you again guys!!
96GTS is offline
post #70 of 72 (permalink) Old 01-06-2019, 05:19 PM
Unboxed frame.
Great info fellas! I have all my parts together to do the swap.
I was talking to a buddy an he said he would be slightly concerned about the unboxed (c-channel) frame section were the shock tower will be installed on the 99-04. Just a concern.... by no means saying its going to fail. Since this year range does not carry the weight of the front end there and is dispersed on a leaf, I assume they saw no need to box this part of the frame. The 05+ sure enough has the frame boxed above the axle and around the shock tower. Has anyone who has been running the conversion for a while had any issues with this?.... cracks, bending, twisting?
thank you!
simonorcal is offline
post #71 of 72 (permalink) Old 01-07-2019, 03:56 PM
thank you!
The newer frames are only gusseted right where the frame and rear of the engine cross member meet. The area where the coil/shock buckets mount is channeled just like the leaf spring trucks. They are both boxed in front of that (where the steering box mounts). I've only had my swap done for 8ish months but I have 2'000+ Baja miles on her. Just hauling ass over crappy roads and chasing/pitting in remote areas down there (didn't want to sound like I'm actually racing/prerunning this beast at race speeds lol).
ZERO regrets about the swap btw. Running 37s on the Carli 4.5" coils and caster adjustable LewisBuilt radius arms (bad ass units)....
simonorcal likes this.
96GTS is offline
post #72 of 72 (permalink) Old 01-14-2019, 11:06 AM
imrdnck's Avatar
I was wondering about this also I just completed the conversion and was wondering if the frame boxing was needed?
imrdnck is offline
