How important is the Boost Gauge? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-14-2005, 09:19 AM Thread Starter
X-man's Avatar
In my '97 I only put in a Pyro and Tran temp. gauge. My '99 will be used to and from work empty and pulling a fifth wheel in the summer on weekends. How important is a Boost gauge and what is the use for it. Knowing this my answer my question. A review of why the gauge is used would be helpfull. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img]
, 4x4, Automatic, CC/SB. Edge Evolution, ISSPRO Gauges and A- pillar mount.
X-man is offline
post #2 of 5 (permalink) Old 03-14-2005, 09:44 AM
kilapapipa's Avatar
My Photos: (13)
Re: How important is the Boost Gauge?
I use mine to make sure the turbo is working up to par because I have run it in the stock setting and with the tuner and taken note of the readings. If the readings ever drop off, I can possibly head off a problem with the turbo or perhaps see a leak in the system like boots needing tightened. Also, the turbo runs 16-18lbs. stock and with a chip, you can get to the 25lbs rating on the stock turbo in a hurry and you may want to back off at that point before getting a ses light.
REBORN 20 Over on 3/2/11- Pics in Gallary- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, ARI TC, JW VB, Walbro 392, TC Lock, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straigt piped and guages, 6637, 203T, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #3 of 5 (permalink) Old 03-14-2005, 10:42 AM
Here's a senario of why you need a Boost Gauge:
Yer pull'n yer FW in the summer, up a hill/grade. Yer in the gear that you can maintain + or - 2600 RPM, you've got 15 to 20 lbs of boost built up and holding, yer EGTs are in the 8 to 950*, yer tranny is in the safe temp range.....
That means, yer make'n all the Horse-Power yer PSD will make (Top of the power curve), at the Boost pressure (Max >safe< boost) yer engine was was designed to make that power at, yer EGTs are within a safe range (no meltdown) and so is yer tranny (no parts on the road).... LIFE IS GOOD.
Take the Boost out of that equation ? you've lost one of the indicators of optimum engine performance. given the right/wrong conditions... you could over boost and set yer SES light, yer PCM will go into a De-fuel mode.... Loss of power (Jack Nicholson look)... Everything is relevent.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
JOE
2K, F-350, XLT, XCAB, 2WD, DRW, 6 Spd, 3.73LS, 4 Pod pillar mnt, EGT, Boost, Trans/Engine temp, Fuel press. guages, Quadzilla 50/75/120,ES AIS w/fender mod, Shimmed FPR, Dahl pre-pump filter, HX Mod, Racor (Mod'd) CCV, Premo oil Refiner, W/Wheel with both TAGs, Banks W/gate actuator, DT466 CPS, 6.0 Intercooler, Banks I/C tubes & DPP boots, 25psi BPRV, Full 4" exhst, AeroTurbine w/exhaust guide, MagnaFlow, Intake Heater Delete, Heater core bypass, 203* Thermo, Coolant Fltr., "Hutch" Tank & Fuel system Mods,fill pipe fix, Mag-Hytec Dif cvr, Fumoto, Bilstiens, SafeTplus Steering Dampner, Centramatic's, Ride Rites, SilverStars, Clear APC Head/Tail/Corner & all Marker lights, 2 850cca Optima's, Ultra Boards, Burlwood Dash, XM radio, Billit Grill (Black). TTMs/C-beters. Pull a 32 ft Montana FW. 102K
BIG JOE is offline
post #4 of 5 (permalink) Old 03-14-2005, 11:24 AM Thread Starter
X-man's Avatar
Sounds good to me. I think I'll put a Boost gauge on this one. I got the Evo in the mail today. I have to try it even though the gauges aren't in yet. [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] But I'll be carefull. [img]/ubbthreads/images/graemlins/wink.gif[/img]
X-man is offline
post #5 of 5 (permalink) Old 03-14-2005, 02:10 PM
Don't do it! You'll regret it. [img]/ubbthreads/images/graemlins/frown.gif[/img]
The boost gauge is indeed a handy reference. If you're modded, you can use it to keep yourself out of the danger zone. If you're not, you can use it to check for leaks.
Either case, I use mine to make sure I don't push it too hard until it is warmed up. I also use them to try to maximize economy. When pulling away from a stop, I try to keep my 7.3 below 5 psi, and my 6.0 below 8 psi.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
DarthSurplus is offline
