how much will rims and tires effect mpg - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 12-24-2009, 05:24 PM Thread Starter
lariat 7.3's Avatar
Send a message via AIM to lariat 7.3
how will 20 in rims and around 33 in tires affect mpg?
2000 f 250 4x4. ccsb
just hit 218,000
38R with Turbo Master
238/80% hybrids
Riff Raff FRx
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
lariat 7.3 is offline
post #2 of 2 (permalink) Old 12-24-2009, 05:54 PM
SmokeyWren's Avatar
My Photos: (45)
MPG is affected by the width and height of your tires, as well as by the tread. The loss of MPG is caused by a bigger tire patch, which results in increased mechanical drag, and by the bigger profile which results in increased aerodynamic drag. Wheel size doesn't matter - it's the meat you put on those wheels that determines any gain or loss in MPG.
How much you loose depends on where you're coming from. In your case you had stock LT235/85R16E tires. Those are 9.3" wide and 31.7 diameter.
The stock tires on Ford 20" rims are LT275/65R20. Those are 11 inches wide and 34" diameter. So almost two inches wider and over 2 inches taller. If you stick with that size tire I'd guess you'll lose about two to three MPG - assuming a calibrated speedo both before and after the change in tire size.
The biggest reasonable-size tire you'd want to run on those 20"x8" rims is 285/65R20. Those are 11.5" wide and 34.7" diameter - i.e., the same as a lot of so-called 35s. Anybody with 35s - and that knows how to calculate accurate MPG - will tell you they cost them about 3 MPG - or more with a more-agressive tread .
My Sierra Blanca (Spanish for White Mountain) in the sig pic was a great pickup for 11.5 years. I sold it several years ago. I drove a hand-me-down 2003 F-150 SuperCrew 4.6L 2V for a while, but it was unacceptable for towing more than a rowboat. Replacement is a 2012 F-150 EcoBoost SuperCrew Lariat that tows my 5,000-pound TT like a dream. Replaced the 2012 with a 2019 F-150 3.5L EcoBoost with max tow.
SmokeyWren is offline
