How/Why and i getting Surge at only 12psi! - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 01-04-2010, 05:21 PM Thread Starter
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
Thumbs down How/Why and i getting Surge at only 12psi!
Ive been starting to notice i DO have surge.. I have a leak somewhere and im only seeing 15-16 psi max.. but today trying to pass a car.. in overdrive, i let the turbo spool a little and gave it about half throttle (not full).. and right around 13psi it started to surge and my needle went from 13-10 back and forth..
ive never had this happen before, even WOT runs.. maybe the denser cold air?
But even if i had no leak, and could make 25 psi, would i still surge at 13??
I DO have the top half of my filter covered with plastic, to prevent water/snow dripping into the filter (for the winter).. but there is still 3/4 of the intake available for air induction.. could this have anything to do with it?
2000 7.3 Extended Cab Long Bed Lariat...
nothing crazy, it carries alot of weight, it tows alot.. has all the 'usual' upgrades plus some..
she breaths well, has extra air and fuel
RIStroker2000 is offline
post #2 of 4 (permalink) Old 01-04-2010, 07:39 PM Thread Starter
does the ATS housing make the turbo louder at all?
post #3 of 4 (permalink) Old 01-05-2010, 06:43 AM
locknload223's Avatar
Since the temps dropped, mine is surging way more and earlier too. I think the colder air definately has something to do with it.
'00 Excursion Limited- 4" lift, Vcodes/F350 block, 315/75/16's, airbags, ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80tow, Drive-Thru, 80econo, 120race, 4" MBRP, 6637, 6.0 I/C, AIH delete, Foil delete, Auto Enginuity .
locknload223 is offline
post #4 of 4 (permalink) Old 01-05-2010, 09:33 AM
My Photos: (19)
Surge is caused by the turbo moving more air than it can handle. With the colder temps the air is definitely more dense and thus you are getting more into the turbo. And yeah, mine would surge that low also. I got an ATS and haven't looked back. I highly recommend it.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
