HPOP Gauge - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 02-28-2005, 12:40 PM Thread Starter
HPOP Gauge
Just picked up the setup to check the HPOP pressure. Now the big question. Where do I hook it up? Found some plugs but that looks like the fuel rail, I could be wrong. A picture would be great.
Thanks,
Greg
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 70000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 197,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
post #2 of 6 (permalink) Old 02-28-2005, 01:09 PM
Re: HPOP Gauge
There are plugs on top of the rail, the front one on the drivers side has the icp sensor in its place. No need to worry about fuel cause they are at the end of the heads and hard to get to.
Just pic one easy to get to, I think they are 5/8" [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Here is a <font color="red">Pic</font>
Icp sensor is the front one, you can see a plug about 6 inches down followed by line from oil pump on the 3rd.
1997 F350 CC SRW 4x4, BTS E40D, 4.10 LS,TDEO, Banks Intercooler, Maddog Stage-2's, 3"downpipe, H-max rev kit, Tymar Intake, JoeServo IDM, Ultralite gauges, Silver-reverse glow guages, Jody Tipton Chip, Magnaflow muffler, Reunel Rear Bumper, Evans Coolant, Best 1/4 mile 14.58
1999 f-350 SRW CC 4X4 AUTO 3.73LS, BTS Tranny, Code W Front springs, Elelbrock IAS shocks, AIS air cleaner, Bill's 2 position chip, DI 4" Aluminized Dynamax exhaust with 3.5" downpipe, Rickson 19.5" wheels,Michelin XDE-MS LR-H(16ply), Hellwig hd sway bars front & rear, 2 layers of Brown Bread, Excursion sound pads at firewall, pillar pod gauges,Tekonsha Prodigy. Cowl Inducted Hood, APC Projector headlamps, APC corner lamps, Carbon fiber Tailamps, Body color grille, cowl panels, door handles, tailgate handle.
Rbob is offline
post #3 of 6 (permalink) Old 02-28-2005, 04:34 PM Thread Starter
Re: HPOP Gauge
Thanks for your help Rbob. I was right but just needed to be reassured.
Greg
EBPV Deleted
Banks Tubes
Terminator
2002 JCB 212s
2004 A300 Bobcat
post #4 of 6 (permalink) Old 02-28-2005, 08:25 PM
Re: HPOP Gauge
What if you have the HX cross over line ? Does that eliminate a spot to install the hpop guage ? I priced the setup for a guage and I can have one built for $ 70.00 with quick connects from the motor to hose.Thanks, Rick
01' F-350 CC,LB,SRW,4x4,BTS,Stealth Oil,DP tuning,ITP fuel,BB turbo,4"turboback exhaust,AFE I,Autometer guages
haulinponies is offline
post #5 of 6 (permalink) Old 03-14-2005, 02:00 PM Thread Starter
Re: HPOP Gauge
Finally had the time to hook up test gauge. Removed the ICP and connected there. When I unplugged the ICP it had oil in the connection. Should it be replaced? At idle I had 700psi. At WOT throttle (3000rpm) I only had 2200-2300si. What should it be? Do I need new HPOP? If so any recommendations?
Thanks Greg
EBPV Deleted
Banks Tubes
Terminator
2002 JCB 212s
2004 A300 Bobcat
post #6 of 6 (permalink) Old 03-14-2005, 02:44 PM
dondiesel444's Avatar
Re: HPOP Gauge
my early 99 has 500 at idle and 2400 at WOT, so were pretty close. mine has 143,000 miles on it. I left the gauge hooked up to one of the plugs on the passenger side head and the hose/gauge tucked under the cowl. when I want to check pressure I put the hose/gauge up by the windsheild wipers so I can see it while driving
2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks:
2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner..
late '99 F-350 PSD CC LWB 4" lift, 315's, DP......
early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc....
1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
dondiesel444 is offline
