Hydra tunes differences - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 01-15-2017, 03:28 PM Thread Starter
What are the differences between the different tunes? Shift points? Or anything else?
Example, there is a 80hp tow, 80hp daily driver, and 80hp performance.
Obviously the tow tunes are for towing, but what is the difference between DD and performance.
I suppose my real question is which tune is best for what situation?
TIA
2002 F250 CC SRW 4x4, 315/75R16, 4" exhaust
dtrojcak is offline
post #2 of 4 (permalink) Old 01-15-2017, 04:09 PM
blue99stroker's Avatar
Shift points.
80 tow will shift later.
Daily driver shifts sooner. And performance is somewhere in the middle.
Daily driver and performance will net good mileage.
blue99stroker is offline
post #3 of 4 (permalink) Old 01-15-2017, 04:14 PM
79jasper's Avatar
You know, sometimes I've wondered the same.
Though I don't recall having a tow tune with a higher hp like that.
But I've noticed I'll get way more smoke in the daily tunes vs the performance tunes.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #4 of 4 (permalink) Old 01-15-2017, 08:38 PM
yan7gin's Avatar
I think the performance tune will dump more fuel at lower rpm and be more prime than the DD. but i might be way off.
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
