Infinity-DX question - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 01-21-2017, 12:31 PM Thread Starter
yan7gin's Avatar
So I'm trying to figure out the VIN thing with the infinity. I have 2 truck, 7.3 2002 and 6.4 2008. If i buy the infinity (come with sd card and 1vin) with one tune for the 6.4. Can i load the tune in my 6.4, remove the device and use it to monitor the 7.3?
If i buy an additional vin with 7.3 tune, can i have both truck tuned at the same time....
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #2 of 6 (permalink) Old 01-24-2017, 06:47 PM
Yes, that is correct.
You do not need an additional VIN license if you want to use the unit as a monitor on another truck. You only need an additional VIN license if you want to tune more than one truck (one VIN license per every truck you want to tune).
Does that make sense?
post #3 of 6 (permalink) Old 01-24-2017, 09:57 PM Thread Starter
yan7gin's Avatar
Thanks Justin, i figure you would of pop by.
Yes it does make sense, my big thing is does the unit need to stay in the truck while it's tune or can i tune my 08, remove the unit and use it in my 02 as display (while the 08 is still tune)
F350 2002 7.3
yan7gin is offline
post #4 of 6 (permalink) Old 01-25-2017, 06:34 PM
No problem.
No, the unit does not need to stay in the truck. You can load the tune, take the unit out, then run it as a monitor in your other truck. That tune will stay loaded until you plug the Infinity back in and change the tune.
post #5 of 6 (permalink) Old 01-25-2017, 07:58 PM Thread Starter
yan7gin's Avatar
Awesome thanks Justin, this will be on my list for next order.
F350 2002 7.3
yan7gin is offline
post #6 of 6 (permalink) Old 01-26-2017, 06:51 PM
No problem!
