Injector choices - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 11-24-2006, 12:39 PM Thread Starter
Injector choices
Hello, I am looking to upgrade my injectors. Was looking @ BDP stage 2 singles or new BD 530's for about the same money. What motor mods would I need for the 530's..turbo,studs? How do the BD's do with towing? Looking for more insight on the 530's. Will be checking what rods I have this week, motor built 10/00.Thanks. Rick
haulinponies is offline
post #2 of 6 (permalink) Old 11-24-2006, 01:00 PM
Feedback Score: -1 reviews
Re: Injector choices
Rods are PMR's. [img]/ubbthreads/images/graemlins/vomit.gif[/img] DI's 530 hybrids are pretty amazing, I tow 12,000 lbs with those sticks. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
DSALF250 is offline
post #3 of 6 (permalink) Old 11-24-2006, 01:59 PM
CSIPSD's Avatar
My Photos: (52)
I am running 180 singles with PMR's... No Issues!
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #4 of 6 (permalink) Old 11-24-2006, 07:12 PM
i would vote for the bdp 2's vs BD's. Bd's are alot of fuel and w/o very good tuning could turn your engine into a bucket of scrap iron. If you do have forged rods id go with hybrids first bc they dont need dual hpop and unless you are shooting for 500++ hybrids are just fine. To be 99% safe with 530's (and run them hard) your going to need a built engine with alot of air.
95 f350 Redneck war wagon- lots o goodies
kellycoon is offline
post #5 of 6 (permalink) Old 11-24-2006, 07:26 PM
Your sig says you already have a Stealth pump. If you have PMR's you will grenade the engine with any performance injectors above stage 1's. I have MM's that work well with my PMR's but use a 40hp maximum tune. I don't dare go with big oil. It's more than maxed out as is.
Use a scope when you check your rods. Otherwise it will leave some question because it's very hard to see clearly through that small hole.
DZ
BTW, my engine was also built 10/00 and has the PMR's.
2001 F250 Lariat, -SOLD-
460/950 Corrected Prior To Water Injection and Spearco IC.
13.974 @ 95.65mph
2008 Cummins Truck Fest 4WD Diesel Champion
'07 Duramax Classic, Leather, Sunroof, Bone Stock.
DZacc is offline
post #6 of 6 (permalink) Old 11-25-2006, 08:08 AM
mmcspadden's Avatar
I recommend Stage II singles but not with big oil and a stock engine. I did not add oil to my truck, see my sig. I did beef up my injectors, turbo and some other stuff. My mods should put me in the 380-400hp range I am told. Still need to get to a dyno to verify. I will say I have plenty of power for fun daily driving and most importantly towing around 14,000lbs of horses and trailer.
My 2 cents.
Mike
1999.5 F250 PSD 4X4
Mgf. Date 07/99
mmcspadden is offline
