Injectors - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 28 (permalink) Old 09-29-2016, 06:11 PM
Originally Posted by 2000F250-7.3 View Post
Thank you it was a big jump I also did a hpop at the same time as the injectors plus new tunes on my Ts chip so it was a combination of all that plus a few fuel mods also.
Yes, all of that stuff will sure wake the truck up. Wait until you do the turbo, you will be even happier.
post #17 of 28 (permalink) Old 09-29-2016, 07:34 PM Thread Starter
2000F250-7.3's Avatar
Justin I just did the turbo I got the powermax GTP38R and what bigger difference. Can't wait to tow my camper now.
2000F250-7.3 is offline
post #18 of 28 (permalink) Old 09-30-2016, 12:20 PM
Yes. Should tow substantially better than before.
post #19 of 28 (permalink) Old 09-07-2017, 01:53 PM Thread Starter
Thanks I will post once I get it running and let you know.
Sent from AutoGuide.com Free App
I am a bit late on a up date for you. But the new set up is amazing great power and towing is great went from 14.5 mpg to 17.5 I like the single shots better than split shot. I am doing a new cold air intake to match the setup. My old stage 2 AFE intake was to small for the injectors and power max turbo.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
post #20 of 28 (permalink) Old 09-07-2017, 02:31 PM
blue99stroker's Avatar
Which Intake did you have?
The stage 2 afe With the relocated battery flowed very well, more than enough for 375-395hp.
The afe Intake that sat in the factory location weren't as good.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #21 of 28 (permalink) Old 09-07-2017, 03:27 PM
yan7gin's Avatar
Just curious why do you say that its too small for those injector?
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #22 of 28 (permalink) Old 09-08-2017, 10:20 AM Thread Starter
I had this intake from AFE. I called there tech support and asked them if this flowed enough or my stage 1.5 and power max turbo. They said to go with the bigger filter that relocated the battery and bigger filter I did not want to spend $425 on it so I went with the 6637 mod from riffraff diesel.
post #23 of 28 (permalink) Old 09-08-2017, 10:27 AM Thread Starter
Hi blue99stroker I was not clear that the one AFE recommended me get to replace my old one that sat in the stock air box. I did the 6637 mod instead a bit cheaper than the AFE unit.
post #24 of 28 (permalink) Old 09-08-2017, 12:32 PM
yan7gin's Avatar
ya 6637 is great, if you want, the S&B is a great filter for 299$
F350 2002 7.3
yan7gin is offline
post #25 of 28 (permalink) Old 09-08-2017, 01:13 PM
That is the afe Intake I thought you had. Those weren't that great.
The stage 2 is ridiculously priced.
The 6637 works well and is cheap.
post #26 of 28 (permalink) Old 11-12-2017, 06:04 PM
Haven't been on here for a while, but am interested in this since I believe my injectors are going. I have been checking some sites on them and find not sure which to do. Have folks here run for many miles the replacements either new or rebuilt. Don't want to spend this kind of money and blow it. Also just so you know I do a lot of towing in the 8,000 to 12,000 lb range so from what I have saw I do not want to change much from stock. Any info on longevity would be helpful to help my decision. And please no bad mouthing a supplier here. I also see where it was said rebuild wear quicker, is that true to anyones knowledge?
rjranch is offline
post #27 of 28 (permalink) Old 11-12-2017, 07:56 PM
New usually lasts longer. But the price is close to double that of a reman Remans.
It?s been awhile since I looked into it, but the poppet valves in the new injectors don?t last as long as the original equipment injectors.
I agree on staying stock injectors. That is the most reliable way to go.
PIS, rosewood, full force get my vote. No particular order of importance
post #28 of 28 (permalink) Old 02-10-2018, 12:28 AM
westvandude's Avatar
I need to do the same thing. Down to 12mpg now stock injectors 209,000 miles. I've run tons of B100 thru as well. Maybe 20,000L last 5yrs!
HPOP area small oil leak. Going to get adrenaline pump. Bigger single shots. Not set on turbo model yet. Currently have stocker with ported housing but exhaust side is apparently very restrictive. Already have 4" turbo-back magna flow. Even replacing just HPOP to adrenaline on stock injectors with hot tunes will wake it up, motor won't fall flat on it's face above 3000rpm anymore. Pulls hard to redline... or so I'm told.
Stock HPOP can't keep up with split shot injectors with dp-tuner 140race or even 80econo tunes when you mat it a lot. Frequent P1211 codes. Runs good now.
But, can always run better.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrenaline HPOP, CRUDE diesel performance HPOP lines, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, Projector headlights w/OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, 15k 5th wheel hitch, Level8 striker 16x8.5 blk rims, etc.
2009 VW JSW 2.0TDI 6spd Highline. Aftermarket android navi 7" touch head unit, tint, GTI grille and projector fogs.
BioPro190 owner. 40,000L produced 2010-2018.
westvandude is offline
