LED flasher part number - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 03-08-2005, 02:40 PM Thread Starter
DIESELSITE's Avatar
Does anyone have the part number for a flasher used for LED lights? Obviously I need to change out the HD unit to a light duty one for LEDs.
Thanks,Bob
Bob Riley, Owner DieselSite.com
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
DIESELSITE is offline
post #2 of 13 (permalink) Old 03-08-2005, 02:55 PM
QtrHorse's Avatar
Re: LED flasher part number
Are you talking about something like this; <font color="blue">LED flasher</font> and this; <font color="red">LED flasher</font> ? Or do you mean the actual flasher that installs in your fuse block?
99.5 F250 XLT S/C 6SPD
ITP Intank ModsLUK clutch w/ Kevlar pilotAFE Stage1Red Top OptimasReflexxion Cowl Hood
QtrHorse is offline
post #3 of 13 (permalink) Old 03-08-2005, 03:08 PM
I dont like Load Equalizers.
Whats the point of installing LEDs if your just going to use a resistor to generate heat.
I see the point to adding LED's as a way to reduce load on the alternator. Load equalizers just add the load back in, that the LED removed.
Ford_Forgotton is offline
post #4 of 13 (permalink) Old 03-08-2005, 04:29 PM
QtrHorse's Avatar
Is that all the load resistors do? If I were to add LED, it would be to use less voltage. That must be why they recommend to not put those load resistors near anything such as plastic, oil or anything flamable. They state that they get very hot.
QtrHorse is offline
post #5 of 13 (permalink) Old 03-08-2005, 04:29 PM
i just installed a light inline on the turn signal wire. its mounted inside the frame rails above spare tire and and taped up real good so you can't see the light when it blinks. (i did one for each for Left and Right)
thomas
<font color="orange"> __________________________________________________ _____________________________</font>
aka Power-Strokin' (234 posts)
<font color="navy">3.73ls VDH2 oxford white/silver metallic, DP-Tuner 4 pos.(40, 70, 100, 125), FTVB, AIS, WD Turbo Brake III, 4" Magna-Flow turbo-back exhaust, wicked wheel, 3 guage A-pillar pod w/ Di-pricol white-face guages, ITP fuel system, after market leather seats (two tone), Super-Liner, "chromed" emblems, CCV mod., BFG AT 295/75-16 on 16 x 10 Ultra Type 50/51 wheels, Rancho RSX, Amsoil bumper-to-bumper, PopUp GN hitch, GOS harness & SilverStars </font>
'04 F250CC Lariat PSD FX4 white/silver, Putco stainless toolbox, stock!!!
AllStarPSD is offline
post #6 of 13 (permalink) Old 03-08-2005, 04:52 PM
Well, technically, LED's use less CURRENT (in addition to most LEDs use less voltage).
Most blinker relays are basically resetting fuses. the current flow warps the metal inside until it breaks contact (current flow generates heat when the wire is thin enough). The regualr bulbs draw enough current to make the blinker work. LED's DO NOT draw enough current and teh blinker goes stupid.
Load equalizers pretend to be regualr bulbs to increase the current flow, but the energy has to go SOMEWHERE so its converted to HEAT.
Hence the need to keep them away from plastic, oil, etc.
post #7 of 13 (permalink) Old 03-09-2005, 12:08 PM
Bob, is this what you are looking for? Ford LED Turn signal flasher
Y2K,F-250 Lariat, PSD,Auto 4X2, NVK4, S.Cab,White, Banks T.O.P. and Muffler, Isspro Gauges, TTM, Sonnax & Tricumulator, Rancho 9000s, AIC, Silverstar Bulbs,SUVLIGHTS Harness,Homebrew "Britebox",Homebrew LED "Strobes", N-fab nerf steps,
Tparker is offline
post #8 of 13 (permalink) Old 03-09-2005, 12:14 PM
now THAT is the correct answer to changing to LEDs. This beats the daylights out of "load equalizers".
post #9 of 13 (permalink) Old 03-09-2005, 01:13 PM Thread Starter
DIESELSITE's Avatar
YES. Thank you!!!!
Bob
post #10 of 13 (permalink) Old 03-09-2005, 08:52 PM
Hey Bob...how about some new pics of the truck since you changed the look.
John
FOR SALE*1996*F250*4X4*<font color="red">RED</font>*CC*SB*E4OD*4:10's*4" Exhaust *Tymar*Factory AIC*SnugTop Shell**NAW4*129,XXX miles
KC Fan is offline
post #11 of 13 (permalink) Old 03-09-2005, 10:03 PM
John
when i talked to Bob tonight he was telling me about the new "look" and he said it was almost ready to pose for pics.
thomas
post #12 of 13 (permalink) Old 03-10-2005, 09:30 PM
Wow, something Bob Riley needed our help on? That's a twist... [img]/ubbthreads/images/graemlins/smile.gif[/img]
Andy
2002 F250 XLT PSD Auto CC SB 2WD. Owned since new.
265/75R16E Bridgestone Dueler AT Revos
Ford AIS Intake w/ Motorcraft Element
Optima 34/78 Red Top Batteries
Fleetguard LF9027 Venturi Oil Filter
22" Wiper Blades
BigJakeJ1s is offline
post #13 of 13 (permalink) Old 03-14-2005, 07:42 AM
Has anyone purchased one of these flasers yet? We went to NAPA to look for it... they didn't have it in stock, but they looked it up and it was about $80. Does that seem right?? I was thinking it would be a bit cheaper than that?
2003 4x4 F250 7.3 Crew Cab Shortbed
fastleft is offline
