Mishimoto radiator hoses - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By ArcticDriver
post #1 of 6 (permalink) Old 12-29-2018, 12:42 PM Thread Starter
Im gonna be flushing my coolant system soon so I figure I might as well change out the hoses too. I saw Mishimoto makes a silicone hose kit that has a lifetime warranty and supposedly gives better burst resistance than rubber. Anyone use these?
2001 F-250 XLT 4x4 7.3; 146,000 miles; 4R100
optimusprime is online now
post #2 of 6 (permalink) Old 01-25-2019, 02:20 AM
I upgraded my hoses with Mishimoto over a year ago. I bought the top hose that goes around the serpentine belt.
The Mishimoto hoses are very heavy duty. They are worth the money. I also installed replaced the thermostat housing with Riffraff Diesel 7.3L Billet Thermostat Housing.
powderhound12 is offline
post #3 of 6 (permalink) Old 01-25-2019, 12:44 PM
https://www.mishimoto.com/mishimoto-...sel-99-03.html
They are now on sale, and they come in three pretty colors.
DonWarkentin is offline
post #4 of 6 (permalink) Old 01-25-2019, 03:23 PM
ArcticDriver's Avatar
The price is $216 for two hoses which cost under $100 for Motorcraft brand and $60 for Gates.
I guess I am still not understanding this but are Powerstroke owners having issues with the conventional rubber hoses bursting under pressure? My original hoses were replaced at 180,000 miles as preventative maintenance and had zero indication of being worn out.
If not then this just seems like a waste of money...although I do like the Blue ones.
JJEdwards likes this.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is online now
post #5 of 6 (permalink) Old 01-25-2019, 07:48 PM
Calico5's Avatar
Yeah, the price tag on the Mishimoto hoses is ridiculous. But the colored stuff can dress-up the engine bay nicely. DieselSite makes a decent pair of hoses as well, but price is even higher than Mishi's (they come in any color you want, as long as it's black).
My original hoses lasted well over 150K, never had a lick of trouble, but were due for a change, so I went with the DieselSite hoses (when I put in the Mishimoto radiator @ 205K). Also, I'm running the T444 water pump, and DieselSite makes/sells a molded lower hose specifically for that application (I had the pump on mine long before they were offering their "kits" for the T444 pumps).
It's to bad Ford doesn't make a "sever duty" silicone hose for other applications, like they do for their Police Interceptor vehicles (Crown Vic's & Explorers). They'd probably sell...
~Al
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #6 of 6 (permalink) Old 01-25-2019, 11:03 PM
If I hadn't already replaced my hoses recently with Gates, then those blue ones would be awfully tempting.
