New GT38 Center Cartridge - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 10-25-2016, 05:55 PM Thread Starter
What exactly is involved when putting a new GT 38 Garrett center cartridge in one's turbo?
Is the unit balanced from the factory and does it require additional balancing once it is installed?
Do remanufactured turbos have an advantage over installing a new center cartridge?
TooCoolTwo is offline
post #2 of 10 (permalink) Old 10-26-2016, 08:42 AM
RT
RT's Avatar
Yes, they are balanced. The advantage for buying the cartridge is time savings- just remove and replace the whole guts. The disadvantage is $$.
Sent from my iPad using Tapatalk
RT is offline
post #3 of 10 (permalink) Old 10-26-2016, 09:13 AM Thread Starter
Thanks, RT. I appreciate you help, advice, and all you do to help everyone out on this forum.
Mike
post #4 of 10 (permalink) Old 10-26-2016, 11:12 AM
blue99stroker's Avatar
Is your current turbo in need of a rebuild?
Does the new cartridge come with a new comp wheel? If it doesn't then you would still need it balanced again if your worried about it.
I rebuilt mine with one of barders 360 kits 20k and it's fine.
blue99stroker is offline
post #5 of 10 (permalink) Old 10-26-2016, 04:01 PM Thread Starter
Blue:
Will not really know until my mechanic removes it to install new up-pipes and non-EBPV pedestal. The replacement unit is a complete, new Garrett center cartridge. Only my old housings are used, I am told.
My turbo is not giving me problems at all. Just figure it must be tired at 225K miles. Not sure I can count on it for another 75K plus miles. Figure it is a good time to replace it while other work is being done.
post #6 of 10 (permalink) Old 10-27-2016, 07:27 AM
I rebuilt mine at 245k for PM as well. I might add it was perfect.
They are a tough unit as long as you don't run really high egts and backpressures.
post #7 of 10 (permalink) Old 12-17-2016, 11:49 PM
yan7gin's Avatar
the turbo is easy access If not broken, I wouldn't touch it. unless you want to upgrade it.
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #8 of 10 (permalink) Old 12-18-2016, 05:24 PM
Relentless007's Avatar
how much did you get the non-EBPV pedestal for? i need to replace mine the stock one has started to leak where the actuator rod goes in at. I already gutted the EBPV in the turbo itself.
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #9 of 10 (permalink) Old 12-18-2016, 06:32 PM
Boy, you come into that home stretch so strong and then.......
then you bring up a "posssible mute point"...
Steven was getting to the fact that a complete center rotating cartridge willl come completely balanced, however it is going to come with a "plain Jane compresssor wheel and most end users preferr a more agressive compresssor wheel. In changing this compresssor wheel out to a diffferent one, this will throw out the whole "toatall balance" as a new "center rotating center cartridhe assembly". I believe Blue was trying into indicate this...
Love 'ya boy
Maryland dieselnick is offline
post #10 of 10 (permalink) Old 12-18-2016, 08:33 PM
Love you to nick!
Ya that's the point I was trying to make nick. If you go through all the effort, then swap a wheel it should be balanced again.
I bought my non ebpv pedestal from riffraff for 100 bucks.
I just picked up a van turbo nick! I will rebuild it with a 360 kit and stick my billet wheel in it. It will be nice to be at 35 psi of boost and 40 psi backpressure.
My stock turbo or like 40 psi boost 70 backpressure haha
These 160/30's are a huge bump in power lol
