Non-EBPV Worthwhile? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 09-28-2016, 09:03 AM Thread Starter
For those who have done installed the non-Enoch pedestal and high flow outer, was it a worthwhile modification, and have you had any problems?
Problems with engine soft codes,performance or mileage differences? Thanks in advance.
TooCoolTwo is offline
post #2 of 11 (permalink) Old 09-28-2016, 09:47 AM
blue99stroker's Avatar
No issues.
Lower egts and one less oil leak to worry about.
Warms up the exact same in the winter as well.
If you don't do something about the plug you will have a soft code but there are a few easy options to fix that
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #3 of 11 (permalink) Old 09-28-2016, 10:24 AM Thread Starter
Thanks, Blue! Appreciate your help.
post #4 of 11 (permalink) Old 09-28-2016, 06:26 PM
yan7gin's Avatar
Same as Blue
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #5 of 11 (permalink) Old 09-28-2016, 08:32 PM
Originally Posted by blue99stroker View Post
No issues.
Blue, not so on line 3 Homefry. Still luv ya though🙂
Maryland dieselnick is offline
post #6 of 11 (permalink) Old 09-28-2016, 09:46 PM
79jasper's Avatar
I noticed no difference. But also I installed a 203 thermostat. Lol
Maybe the further north you are, the more it would help.
But in freezing Temps, I found it better to just drive it vs idling waiting on it to warmup.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #7 of 11 (permalink) Old 09-28-2016, 10:22 PM
yan7gin's Avatar
I also have the 203 stat and same as blue I didn't see much difference during warm with or without the EBPV. But the coldest it get here is about 14f LOL
F350 2002 7.3
yan7gin is offline
post #8 of 11 (permalink) Old 09-28-2016, 10:35 PM
2000F250-7.3's Avatar
I noticed a small drop in egt's and it got rid of a oil leak is the two main reasons to do it. Warm up stays the same.
2000F250-7.3 is offline
post #9 of 11 (permalink) Old 09-29-2016, 07:31 AM
Nick once it switches to high idle I notice no difference.
But I also use 5w-40 oil so it's not struggling to run with thick oil when it's cold.
post #10 of 11 (permalink) Old 09-29-2016, 08:43 AM
Valley is liquid free no issues
2002 lariat F250 CC,4x4, 145k, MBRP exh, AFE II, 6.0 cooler, EBV delete, IAH delete, Firestone air bags, led headlights, revelco, autometer pyro & trans temp, retrax, 2013 artic fox 22H, husa FE250
drtrash is offline
post #11 of 11 (permalink) Old 09-29-2016, 09:19 PM
I have done lots of mods over the years and about the only ones that I saw any real change was a chip and flush of PS with AMSOIL (stopped squeal). I live in Alaska and have been without a EBPV for several years. One thing I don't do is let truck sit and idle to warm up for 5-10 min. Just get in start and drive easy until temp comes up (3-5 min). On a side note if you have a coolant filter how you run the return line will make a big difference in a 7.3 as far as getting heat to the defroster/heater.
I just bought a new to me 99 with 56,000 on the clock. I will leave the EBPV in unless it starts to leak a lot than I would just change pedestal if that happens.
DENNY
DENNY is offline
