Oil for the 7.3L - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 27 (permalink) Old 07-26-2018, 04:15 PM Thread Starter
Maine7.3's Avatar
Oil for the 7.3L
Ok you guys have had a diesel longer than me.What oil and filter do you recommend.And what oil and filter to stay away from.
Maine7.3 is offline
post #2 of 27 (permalink) Old 07-26-2018, 04:30 PM
jleedog's Avatar
Try to only use the OEM motocraft fiter FL1995. As far as oil I use Rotella T6 full synthetic, but that is just me.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #3 of 27 (permalink) Old 07-26-2018, 05:28 PM
badbart's Avatar
Ford Approved Oils For Diesels:
https://www.fcsdchemicalsandlubrican...SSM2C171F1.pdf
All oils should be WSS-M2C171-F1 compliant. I personally use the Motorcraft brand following the logic that it was good enough to be selected by Ford for use in their diesels.
2011 F350 4x4 XL Crew Cab Dually
2010 Keystone Fuzion 405 Toyhauler
badbart is offline
post #4 of 27 (permalink) Old 07-26-2018, 08:19 PM
ArcticDriver's Avatar
As said above the Motorcraft FL-1995. It can be found at WalMart for $9.90
Rotella T6.
Chevron Delo 400.
Mobil Delvac.
I buy the top two brands at WalMart and the Delvac at Murdochs Ranch Supply in 5-gallon buckets.
Just to name a few.
I prefer full synthetic because they allow for longer Oil Change Intervals (OCI).
Many here seem to hold to 5,000 OCI for full synthetics.
Traildust likes this.
SOLD:
ArcticDriver is online now
post #5 of 27 (permalink) Old 07-26-2018, 09:21 PM
Dieselgunner
Guest
Posts: n/a
I always use rotella 15w-40 with either 1 quart winter or 2 quart summer of lucas oil stabilizer and I would recommend the motocraft filter if you want the best.
post #6 of 27 (permalink) Old 07-26-2018, 09:47 PM
Yes, it's unanimous. We all use rotella T6 with the Motorcraft filter. So far, at least.
DonWarkentin is offline
post #7 of 27 (permalink) Old 07-26-2018, 10:14 PM
bugman's Avatar
My Photos: (12)
Valvoline Premium Blue 15w40 since my truck was new. It had its first oil change at the dealer but other than that it has been done in my driveway.
On filters I got a great buy on two cases of Wix and ran them until they were gone, now it is back to the 1995.
bugman is online now
post #8 of 27 (permalink) Old 07-27-2018, 01:04 AM
Many 7.3 owners do not recommend using oil additives such as Lucas products.
There have been possible injector related issues in the 7.3 Powerstrokes if I recall correctly.
My own opinion is that it is not necessary to use an oil additive when using a high quality HDEO.
Some guys do say the 6.0 which experiences stiction has shown benefit by adding Archoil but stiction is not common for a 7.3
SOLD:
post #9 of 27 (permalink) Old 09-09-2018, 05:10 PM
Calico5's Avatar
Started out using Rotella T, but then switched to Valvoline "Premium Blue" synthetic, 5W-40 (many years ago), and usually only the genuine Motorcraft FL-1995 filters (Wallyworld seems to be the cheapest seller...).
Occasionally I'll use a Wix or NAPA brand filter, but they are always more expensive than the 1995.
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #10 of 27 (permalink) Old 09-11-2018, 11:07 PM
79jasper's Avatar
Monolec....
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #11 of 27 (permalink) Old 09-11-2018, 11:18 PM
Originally Posted by losfinch View Post
Shaeffers Full Synthetic 9000 (5W40), Mobile One Filter on the motor and frame mounted Amzoil bypass filter. At 10,000 I change out the Mobile One filter and top off the oil. Then at 20,000 I do a complete oil change and replace both filters.
Do you have any UOAs to post?
Is your motivation cost savings?
IIRC, your driving conditions are “severe” as defined by the Owners Manual?
SOLD:
post #12 of 27 (permalink) Old 09-12-2018, 05:20 AM
Originally Posted by 79jasper View Post
Monolec....
I hope you get this through your employer at some kind of discount.
Its expensive.
SOLD:
post #13 of 27 (permalink) Old 09-12-2018, 06:26 AM
79jasper's Avatar
Its expensive.
Through Employer?..... Lol
It's really no different than any of the other big names.
About $150 for a 5 gallon bucket shipped to my door in 2-3 days.
79jasper is offline
post #14 of 27 (permalink) Old 09-12-2018, 09:53 AM
losfinch's Avatar
No UOAs to report. I did some a while back and things were fine but anymore I'm just going by what I feel is a good, conservative time and mileage frame for what most people running full synthetic and bypass systems do. Motivation? I was motivated primarily by wanting to cut down on the amount of supplies I had to haul down here (Mexico) to change the oil and filters. One full oil change every 20,000 is a lot less oil and filters than every 5000 as I was doing before. It does come out a little cheaper, too, which is a nice side benefit but not the primary motivation. Also, I like having a high quality oil in the motor and the Mobile One filters have a better filtration rating than the OEM Ford ones IIRC. I also like the cold weather starting ease that comes with the full synthetic oil as well. And, yes, according to the manual my conditions are "severe."
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #15 of 27 (permalink) Old 09-13-2018, 07:20 AM
Its expensive.
You have found a good price...Lol
SOLD:
