Oil for the 7.3L - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 27 (permalink) Old 09-13-2018, 08:21 AM
ArcticDriver's Avatar
Originally Posted by losfinch View Post
Originally Posted by ArcticDriver View Post
Do you have any UOAs to post?
Is your motivation cost savings?
IIRC, your driving conditions are “severe” as defined by the Owners Manual?
No UOAs to report. I did some a while back and things were fine but anymore I'm just going by what I feel is a good, conservative time and mileage frame for what most people running full synthetic and bypass systems do. Motivation? I was motivated primarily by wanting to cut down on the amount of supplies I had to haul down here (Mexico) to change the oil and filters. One full oil change every 20,000 is a lot less oil and filters than every 5000 as I was doing before. It does come out a little cheaper, too, which is a nice side benefit but not the primary motivation. Also, I like having a high quality oil in the motor and the Mobile One filters have a better filtration rating than the OEM Ford ones IIRC. I also like the cold weather starting ease that comes with the full synthetic oil as well. And, yes, according to the manual my conditions are "severe."
Thanks for the insightful response.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #17 of 27 (permalink) Old 09-13-2018, 08:23 AM
79jasper's Avatar
You have found a good price...Lol
"I know a guy." Lol
He'll sell to anyone that wants to call/text him. Same prices as if it were someone else.
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is online now
post #18 of 27 (permalink) Old 09-30-2018, 12:50 AM
I use wallmart 15/40 and change it once or twice a year. Bought the truck with 125000 km and now has 470000
bcguide is offline
post #19 of 27 (permalink) Old 11-22-2018, 10:58 PM
late to the party but I use chevron delo from walmart, Mobil delvac is also very good and is now cheaper around $10/gal. I used rotella when i first bought my truck in 06 I like chevron/delvac much better. made my engine louder/noisier. won't touch the stuff after.
Big R, tractor supply, etc have sales on mobile delvac where you can get it extremely cheap if you can afford to buy by the pallet. I use baldwin filters but would prefer fleetguard or donaldson...just my opinion
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans, 1023, SDK, GH tuned/250/100 FF inj's, Irate T4 w/369SXE, Swamps HVHF IDM, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Donaldson Blue(6637)/AFE BHAF, RR Boots/ Billet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #20 of 27 (permalink) Old 11-23-2018, 01:01 AM
Exactly the same for me.
Started with Rotella T6.
Engine sounded better on DELO 400 LE 5w40:
https://cglapps.chevron.com/msdspds/...&docFormat=PDF
WalMart quit stocking the LE right about the time I switched to DELVAC 5w40 in 5-gallon buckets for $125 minus a $60 rebate which is still active until end of 2018.
The only inconvenience is the 5-gallon pail. Best to use a hand pump or pour into a 4-quart steel oilcan with spout:
SOLD:
post #21 of 27 (permalink) Old 11-23-2018, 02:37 PM
NYB
At a 20K OCI with a good quality synthetic, I wouldn't be worried about engine wear... I'd be worried about the depletion of the anti aeration additive package and the reduced performance of the oil... not as a lubricant, but as a hydraulic fluid providing the motive power for the injectors... where entrained air from the constantly churning oil would likely reduce the effectiveness of the oil's hydraulic function. Not a concern in a common rail fuel system, but something that International often said is a concern with a HEUI system.
NYB is offline
post #22 of 27 (permalink) Old 11-23-2018, 09:45 PM
blue99stroker's Avatar
And unfortunately quite a few CK4 oil’s are under 1k of zddp to help cat/DPF life.
Some are still ok.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #23 of 27 (permalink) Old 11-23-2018, 10:20 PM
I was running Rotella T6 5W-40, but that was before CK-4 oils came out. I still had a pretty good stash of CJ-4 oils to work with, but I've only got enough for one more oil change.
I'll steer clear of CK-4 oils. Next time I buy oil, it'll be Schaeffer Supreme 9000 Full Synthetic Oil 5W-40, it's still CJ-4, for now. If I'm on the road and need oil, I'll stick with the WSS-M2C171-F1 oils with the Motorcraft logo on the bottle.
For filters, here's what I've found...
The absolute most efficient primary lube oil filter you can get for a 7.3 is the Donaldson DBL7405. (intended for a Caterpillar 3406) It's rated at 7 microns nominal, and 15 microns absolute. But this filter gets dented by my front suspension when it flexes, so I don't run it anymore.
The second most efficient filter I can find is the Donaldson P550371, it's rated at 17 microns absolute.
The third best I can find is the OEM Motorcraft FL-1995, according to Ford's website it's 18 microns absolute.
There's a lot of hype about the Wix 51734XE & Napa 1734XE oil filters, but the published beta ratios are 4 @ 10 microns (absolutely incredible) and 75 @ 30 microns (less than mediocre). I'm inclined to think they've mistyped something because that's a wide range of good-to-bad performance in a single filter.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump, Amsoil bypass filter, Coolant filter too
txgp17 is offline
post #24 of 27 (permalink) Old 11-24-2018, 12:15 AM
Excellent consideration.
SOLD:
post #25 of 27 (permalink) Old 11-24-2018, 12:19 AM
Some are still ok.
OK, I know you guys have heard it from me a dozen times already but thats why I bought 40-gallons of the Delvac 5w-40. I had to hit every Murdochs Ranch Supply along the Front Range and Laramie to get every bucket left of the CJ-4 inventories.
I know...probably much ado about nothing 😉
SOLD:
post #26 of 27 (permalink) Old 11-24-2018, 12:21 AM
I'll steer clear of CK-4 oils. Next time I buy oil, it'll be Schaeffer Supreme 9000™️ Full Synthetic Oil 5W-40, it's still CJ-4, for now. If I'm on the road and need oil, I'll stick with the WSS-M2C171-F1 oils with the Motorcraft logo on the bottle.
There was a time I used to know what all that meant.
SOLD:
post #27 of 27 (permalink) Old 11-24-2018, 12:33 AM
Rotella 5w-40 is around 1100 ppm of each zinc and phos
Delo 5w-40 is around 680 zinc and 750 phos Yikes
Yet delo claims 70% better wear protection.
The ck4 is supposed to have better anti aeration additives
