Old Chip - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 02-17-2019, 11:57 AM Thread Starter
Old Chip
I have an unknown old chip currently in my 2000 F350. The truck runs great but I am considering updating to the Hydra to have more tuning options. I have no idea who manufactured the current chip. The old chip installation instructions came with the truck but nowhere in them does it say the brand of the old chip. Maybe one of you can recognize the brand by looking at the instructions? I will try to attach a couple pics
2000 F350 DRW 7.3
tomlin is offline
post #2 of 13 (permalink) Old 02-19-2019, 09:52 AM
blue99stroker's Avatar
It’s probably an old superchips, van aaken, Banks, hypertech
Hydra will be a night and day difference
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #3 of 13 (permalink) Old 02-19-2019, 12:16 PM Thread Starter
Thanks Blue. That's what I was thinking as well. I have a shop but I am going to wait until the weather warms up before I get the Hydra.
2000 F350 DRW 7.3
tomlin is offline
post #4 of 13 (permalink) Old 02-20-2019, 10:18 AM
Since you already have a chip installed it will only take you 5 minutes or so to install the new one.
It takes 5-10 minutes to get all the tunes picked out and loaded
post #5 of 13 (permalink) Old 02-20-2019, 01:11 PM Thread Starter
So you think I can go ahead and install it without removing the PCM from the truck? I did notice the back of the plastic cover is notched out and the chip has duct tape on it. I know that may sound like a stupid question but I have honestly never installed a chip in one of these.
2000 F350 DRW 7.3
tomlin is offline
post #6 of 13 (permalink) Old 02-20-2019, 01:36 PM
Big Horn's Avatar
When I bought my TS-6 I found that someone had cut the back of the plastic tray out as you describe..... I cut a thin piece of plexiglass to go on the inside, reducing the hole, and to keep pressure on the chip so it couldnt vibrate loose on rough roads.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #7 of 13 (permalink) Old 02-20-2019, 02:53 PM
bugman's Avatar
My Photos: (12)
The duct tape is used to hold the chip in place. The last thing that you want to happen is for the chip to work loose and loose contact with the PCM. Worse case you would loose the PCM if there is power to it when the chip comes loose.
bugman is offline
post #8 of 13 (permalink) Old 02-20-2019, 06:50 PM
Big Horn's Avatar
Also, can you see how clean the contact surface is? Mine wasn’t clean enough per the manufacturer. I actually removed screws, split the case, cleaned and made sure no dust was left on the computer board. It is simply amazing to me the work that some people do with little to no attention to detail.
Big Horn is offline
post #9 of 13 (permalink) Old 02-20-2019, 07:32 PM Thread Starter
I pay very close attention to detail.. I am planning to pull the PCM to remove the old chip. I want to make sure that the contacts are clean. It is a ZF6 truck and from what I understand the clutch pedal makes removal a bit difficult. That's why I asked the question about removing and installing the chip without removing the PCM. It looks entirely possible but I don't want to screw it up or cause issues with dirty contacts.
2000 F350 DRW 7.3
tomlin is offline
post #10 of 13 (permalink) Old 02-20-2019, 08:02 PM
Big Horn's Avatar
You won’t have any problems with following the install directions. “Attention to detail” wasn’t directed at you personally but a general comment on not only what I’ve ran into with my truck (2002 F350) but what I see everyday and at work 🙄. Chip manufacturers may be different— my board wasn’t cleaned down very well, and had a silver/gray coating still on the Contacts- TS performance is very clear that they want the contacts down to Copper color and did warn against allowing a chip to come loose. As stated I have the plexiglass insert which made chip fit snug and then duct tape over that—-virtually impossible to get jarred loose.
Big Horn is offline
post #11 of 13 (permalink) Old 02-21-2019, 06:42 AM Thread Starter
No worries Big Horn, nothing was taken personally. The 'attention to detail' has come with age. I appreciate all the comments from everyone. I have been honestly trying to talk myself into doing this job for some time but been dragging my feet. You know, 'if it ain't broke don't fix it'? We have all been there. I am concerned with not knowing who's chip is currently on the truck. Some of those early chips ran a lot of timing and thats not a good thing.
2000 F350 DRW 7.3
tomlin is offline
post #12 of 13 (permalink) Old 02-21-2019, 09:23 AM
69mach1377's Avatar
I am a foot dragger also...the help from guys here and bro-in-law gives me the confidence to tackle almost any diy job. So buy the parts and put them in!
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #13 of 13 (permalink) Old 03-23-2019, 12:25 PM Thread Starter
Well I got the Hydra installed with 1023 tunes and cannot quit smiling. Wow! is an understatement. So far so good, no broken parts. I have a few pics of the old chip but still no ID. Looks like a multi position chip since it has a 4 pin connector but it did not have an external switch or knob.
2000 F350 DRW 7.3
tomlin is offline
Similar Threads
Chip Problems jav401man Power Strokes 1994-1997 Upgrades and Aftermarket 1 06-12-2007 11:18 PM
Secureing a chip in PCM JimTJr '99 & up Upgrades and Aftermarket - 7.3L Engine 5 06-11-2007 05:19 PM
Chip problems ( Banks OttoMind) wont start thechem '99 & up Upgrades and Aftermarket - 7.3L Engine 2 03-02-2007 02:16 PM
Thoughts on new chip PSDVanMan E-Series Vans 26 10-06-2002 07:41 PM
Just purchased the Tri Chip from Western Diesel. pwhitson Power Stroke Excursions 13 12-26-2001 02:54 PM
