PHP Hydra problem - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-24-2019, 09:05 PM Thread Starter
PHP Hydra problem
I just installed a new PHP Hydra chip and am having a problem. I have a new PCM along with this new chip. On all of the programs sometimes the throttle response is dead on and at other times it's lethargic. Sometimes the SES light comes on and the engine will go into a limp mode. Other times it runs like a scalded cat. There are times when I let off the throttle the engine will lope several times and then just die other times it will idle just fine just a little higher than normal. It seams the 2 dialer driver modes are the worst. Has anyone else had these symptoms or suggestions on how to remedy the problem. Yes, I did download the suggested tunes according to the code of my new PCM.
'03Mach1 is offline
post #2 of 6 (permalink) Old 09-25-2019, 10:07 AM
69mach1377's Avatar
Did you make sure the contacts were super clean?
2000 F250 XLT 4x4 SC 7.3 w/rebuilt 4R100, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods, lakes and streams if possible.
See my album for a recent pic.
69mach1377 is offline
post #3 of 6 (permalink) Old 09-25-2019, 07:00 PM Thread Starter
Yes, I made sure to disconnect both batteries, clean contacts but not to the point that the bars are copper.
'03Mach1 is offline
post #4 of 6 (permalink) Old 09-26-2019, 09:42 AM
69mach1377's Avatar
I think the advice was to use a pencil eraser as they are coated with something...
post #5 of 6 (permalink) Old 09-26-2019, 08:34 PM Thread Starter
I used the brass brush and scotch-brite pad supplied to clean the contacts as instructed. Would the use of dielectric grease be good on the chip/PCM contact?
'03Mach1 is offline
post #6 of 6 (permalink) Old 09-27-2019, 09:33 AM
69mach1377's Avatar
I'm not sure, hoping someone else might chime in. Did you contact their support team yet? They are pretty good at it.
