Power stroke problems - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 09-10-2018, 05:32 AM Thread Starter
Having problems with my 03 f350 with the 7.3.
Jspar is offline
post #2 of 4 (permalink) Old 09-10-2018, 09:32 PM
What sort of problems?
DonWarkentin is offline
post #3 of 4 (permalink) Old 09-10-2018, 09:44 PM
Calico5's Avatar
Wow, that's pretty vague...
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #4 of 4 (permalink) Old 09-11-2018, 12:41 AM
Does it start at all?
