PSC Power Steering - Diesel Forum - TheDieselStop.com
LinkBack Thread Tools
Old 08-07-2018, 09:28 PM Thread Starter
Cool PSC Power Steering
My 01 is in need of a new power steering pump. I have read about the pitfalls of the stock pump, issues with the AGR pump and praises on the PSC pump. Most the the info and conversations I am reading on the PSC pump are a decade or older. Has anyone come up with a better mouse trap in the last ten years for the 7.3?
The Grand Pooh-Bah is offline
Old 08-08-2018, 12:39 PM
I would say a Redhead steering box. They have a straight reman version, or the beefed up version is only about $100 more. I would say most people get the beefed up version. RiffRaff, CNC Fab (I think), 1023 Diesel all sell the Redhead box. I have one and it is stronger than stock. PSC stuff is expensive.
https://www.redheadsteeringgears.com/
If you have big tires and a big wallet you could look at PSC full kit with Hydro assist. However, you can also get a Redhead and send to West Texas Offroad for the "redneck ram" hydro assist for less money and most say it is a better system anyways. I have no experience with hydro assist, but I have been researching it because I think it is something I want.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
Old 08-08-2018, 01:31 PM
79jasper's Avatar
Make sure you do plenty of research before even thinking of redhead.
There's bluetop as well.
Sent from my SAMSUNG-SM-G920A using Tapatalk
79jasper is online now
Old 08-08-2018, 02:46 PM
Phil G.'s Avatar
His post reads to me that he is looking for pump, not a box.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog - *Updated 8/18 with Edge CTS2 install click here =>*:
Phil G. is offline
Old 08-08-2018, 03:42 PM
79jasper's Avatar
You right.....
Old 08-08-2018, 04:24 PM
blue99stroker's Avatar
But a good box makes the difference.
You will want a larger cooler if you install a psc pump to help with the Heat of higher pressure.
A larger output pump won’t make a difference on an oem steering box.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
Old 08-09-2018, 08:05 AM
I've had both the Redhead steering box and hydro assist on my trucks. The Redhead steering box is something I will have on ANY Ford truck I ever have now. The amount of play it takes out is great. I also have a steering box that is tapped for hydro assist. Redhead was easy to work with with rebuilding it. The hydro assist was on one of my superduty's with 37" tires and steered great. The box is now on my Excursion without the hydro assist and stock size tires.
Hydro Assist Setup
2000 Excursion 7.3L Diesel 4x4, BTS Tranny, AFE intake,Stage1 Single Shot Injectors , GTP38R turbo, EBV delete, 6 position TS chip, Adrenaline HPOP
kcastle is offline
Old 08-09-2018, 09:43 AM
I definitely read that wrong with regards to looking at a pump and not a box. My apologies.
Old 08-09-2018, 09:54 AM Thread Starter
Thanks for the info on the steering box and ram but I need a new PUMP right now. This is a daily driver with one inch over stock on the tires (height & width) I'm looking for reliability over the stock. Need suggestions on a new pump, the ram and steering box might come next. What pump do you use to run the ram and make that redhead work flawlessly?
2001 F250 CC 4x4 7.3
  • ATS Exhaust
  • Riffraff Intake
  • PHP Hydra Chip
  • 285/75R16 Toyo Open Country R/T
  • Access Bed Cover
  • 05-07 Harley Headlights with Morimoto 55w D2S 5.0 Projectors / 80mm RGB Halos / RGB Demon Eyes / Morimoto Bluetooth Controller / Yellow LED Strip / Switchback LED Turn signal
  • Raptor Style Grill
Old 08-09-2018, 01:20 PM
Check out the re-manufactured pumps on Rockauto and other sites. A few have Motorcraft pumps as well. I also would not shy away from a few of the other brands. All of my pumps were stock and filled with Synthetic ATF. The only other change I made to the system was when replacing the power steering hose going from the pump to the hydroboost unit. I had a hose made with a larger bore when I needed to replace it.
kcastle is offline
Old 08-10-2018, 09:45 AM Thread Starter
Correct me if I'm wrong. For the most bang for my buck. I should find a quality stock pump, have my steering box upgraded, install a cooler and add a Ram.
How does the rebuild of the steering box compare between West Texas Offroad, Blue-Top Steering and Redhead?
Is there anything I need to do at the brakes for the above setup to work properly?
  • ATS Exhaust
  • Riffraff Intake
  • PHP Hydra Chip
  • Access Bed Cover
Old 08-10-2018, 12:18 PM
79jasper's Avatar
I wouldn't worry about the ram assist.
I'm on 35's and have No issues. And I need to flush my fluid.
Just go to Google and search about each box. Me personally, I won't buy a redhead.
May be fine for you though.
For the pump, I would go over stock. Psc, agr, etc.
Old 08-18-2018, 11:53 AM
I used the PCS pump and kit and I haven't looked back. I can turn the wheel as fast as I want at idle and it want bogg down. Best of all no more whining!
Triton28 is offline
Old 08-19-2018, 06:21 AM
The ram in my picture above came from westtexasoffroad and they also tapped my steering box a couple years before I had redhead rebuild it. Both vendors were good to work with. They recommend a 1.5" ram for 37" tires and above. These trucks do not need it for smaller than that.
That being said, I got really use to the feel of having hydraulic assist on my steering. I've considered running a smaller 1" or 1.25" ram assist on my Excursion with stock size tires.
kcastle is offline
Old 08-28-2018, 11:06 PM
yan7gin's Avatar
For the pump ill stick with oem. I had a good talk with Ryan the owner of blue top and he does not recommend the higher pressure pump at all. Rest of the system is not build for that pressure and will be hard on the seal. And as Blue99stroker mentioned the heat is also An "issue" with higher pressure
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
