Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   '99 & up Upgrades and Aftermarket - 7.3L Engine (https://www.thedieselstop.com/forums/f25/)
-   -   School me about Block heaters (https://www.thedieselstop.com/forums/f25/school-me-about-block-heaters-75737/)
Broncofun 11-12-2005 11:20 PM
I have a 99 PSD and I only plug it in during the winter months. Sometimes after the block heater has been plugged in I can feel the warmth in the plugs and sometimes not. The truck doesn't seem to get warm that quickly after using it sometimes. Is there a way to check it? Where does it go into the block and how much are they? Are they a pain to replace? I tried a search but I kept getting no matches. Thanks for any info.
Shawn
wik 11-13-2005 12:46 AM
Re: School me about Block heaters
I could always here water movement when I plugged my 93 in. I have not plugged in the the 2000 yet.
The heaters go into the side of the block. Well, they did on my 93, have not really looked at my 2000. Fairley cheap to buy at a auto store of farm fleet. Easy to install.
smokin_stroke96 11-13-2005 01:02 PM
the block heater on the psd are in the oil cooler housing just above the oil filter. as for replacing one i have never done it i just kept good glow plugs and a good relay in. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
SmokeyWren 11-13-2005 05:37 PM
Is there a way to check it? Where does it go into the block ...
Crawl under the truck with your head under the oil filter. Look up to the base of the oil filter and you'll see the part that sticks out of the water jacket. Here's what you'll see:
http://photos.thedieselstop.com/data...4-0423_IMG.JPG
After it's plugged on for at least a couple of hours, the block heater and the metal housing the block heater screws into should be warm. If not, then yours may be burned out.
The oil filter base is also one end of the engine oil cooler. The block heater is emerged in a water jacket - not an oil jacket. In case you were scratching your head. ;)
If you have any sort of instrument that will show watts of shore power being used, it should work on the line to the block heater. It uses 1000 watts, so your instrument should show somewhere in the neighborhood of 1000 watts.
Broncofun 11-15-2005 12:25 PM
Thanks everyone for the help. I will check it out today since its not raining and let you all know what I found.
68EB 11-15-2005 01:05 PM
Speeking of block heaters the cord on mine is junk. Can I get just the cord or is it a complete assembly?
Andy
Fat Diesel 11-15-2005 01:45 PM
You might want to try one of THESE WOLVERINE HEATERS.
garyt 11-15-2005 04:56 PM
Wolverine is the way to go, I do not even use my OEM block heater any longer unles it is going to be way below zero.
garyT
klhansen 11-15-2005 07:36 PM
Yes, you can just replace the cord. Or if the plug-in end is bad, you can just cut it off and wire on a Marinco Charger Inlet
Makes plugging in easy - Look Ma, only one hand! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
drmiller100 11-15-2005 09:19 PM
heating the coolant is a LOT better then heating the oil. Heating the oil can burn the oil. Besides, warm oil doesn't help the engine start.
heating the coolant using a block heater means the HEAD will get warmer. Most of the water circulates up to the head.
Then when you crank the engine over to start it, the head is warm, top of the block is warm, vavles are already warm, and the truck will start more quickly.
mattA 11-15-2005 10:20 PM
in the winter months here, it does get cold, however, i have mine setup on a timer, i plug it in at night, but the cord going outside doesnt kick the juice on till 2am, that lets it run for 3 1/2 hours before i fire it in the morning, i see no need to leave it plugged in all night, and it was a pita replacing the one on my dads old 91(i cant really rember for sure, but i think it was) and i dont feel the need to pay for the electrical usage, within the 3 1/2 hours its plugged in for, it will melt the snow on the hood, that usually tells me its working, and yes, my cord ends to get alittle warm.
JECHKAEL 12-16-2009 11:57 PM
I am looking for suggestions for installing and circulating coolant heater. Anyone got some ideas/instructions/locations for taping in?
SmokeyWren 12-17-2009 08:06 PM
If it's your 2002 you're talking about, you already have a circulating coolant heater, the so-called block heater.
Look at the photo in my earlier post. If yours has that orange cord coming out of the base of the oil filter, you already have the block heater and the cord to plug it in. You just need to find the plug end of that cord behind the front bumper and plug it in.
If yours doesn't have that orange cord, then all you need to buy is the cord. The heating element is already there. The special cord for the block heater is higher than a cat's back, but it's a lot cheaper that buying a whole new block heater.
Flywheel 12-17-2009 10:29 PM
What are you looking to do?
AndrewExe 12-17-2009 10:50 PM
is the 00' the same way
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
