School me about Block heaters - Diesel Forum - TheDieselStop.com
post #1 of 23 (permalink) Old 11-12-2005, 11:20 PM Thread Starter
I have a 99 PSD and I only plug it in during the winter months. Sometimes after the block heater has been plugged in I can feel the warmth in the plugs and sometimes not. The truck doesn't seem to get warm that quickly after using it sometimes. Is there a way to check it? Where does it go into the block and how much are they? Are they a pain to replace? I tried a search but I kept getting no matches. Thanks for any info.
Shawn
Broncofun is offline
post #2 of 23 (permalink) Old 11-13-2005, 12:46 AM
wik
Re: School me about Block heaters
I could always here water movement when I plugged my 93 in. I have not plugged in the the 2000 yet.
The heaters go into the side of the block. Well, they did on my 93, have not really looked at my 2000. Fairley cheap to buy at a auto store of farm fleet. Easy to install.
'93 F250 XLT 7.3 XC LB 2wd IDI 464,000+ original miles - Died 4/5/05
'00 F250 XLT CC SB 4wd PSD
wik is offline
post #3 of 23 (permalink) Old 11-13-2005, 01:02 PM
the block heater on the psd are in the oil cooler housing just above the oil filter. as for replacing one i have never done it i just kept good glow plugs and a good relay in. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Kortney
MINE::
The Truck: 2002 psd,True Blue Metallic,CC,SB,4X4 ESOF,Auto,Ultra Polished Wheels,285/75/16 Tires, Acetone Badges,
The Mods
DP-Tuner F5,GDS stage 2's,Garrett 38R, Stealth HPOS, TC Lock Up Mod,CCV Mod, Overboost Eliminator, 4in Turbo Back Straight Pipe,AIH Delete and Code Eliminator,EBPV Removed,K&N Filter In Custom Box,Isspro EV Marine Quad gauges,Sonax tricumulator.
smokin_stroke96 is offline
post #4 of 23 (permalink) Old 11-13-2005, 05:37 PM
SmokeyWren's Avatar
My Photos: (45)
Is there a way to check it? Where does it go into the block ...
Crawl under the truck with your head under the oil filter. Look up to the base of the oil filter and you'll see the part that sticks out of the water jacket. Here's what you'll see:
After it's plugged on for at least a couple of hours, the block heater and the metal housing the block heater screws into should be warm. If not, then yours may be burned out.
The oil filter base is also one end of the engine oil cooler. The block heater is emerged in a water jacket - not an oil jacket. In case you were scratching your head.
If you have any sort of instrument that will show watts of shore power being used, it should work on the line to the block heater. It uses 1000 watts, so your instrument should show somewhere in the neighborhood of 1000 watts.
My Sierra Blanca (Spanish for White Mountain) in the sig pic was a great pickup for 11.5 years. I sold it several years ago. I drove a hand-me-down 2003 F-150 SuperCrew 4.6L 2V for a while, but it was unacceptable for towing more than a rowboat. Replacement is a 2012 F-150 EcoBoost SuperCrew Lariat that tows my 5,000-pound TT like a dream. Replaced the 2012 with a 2019 F-150 3.5L EcoBoost with max tow.
Last edited by SmokeyWren; 12-17-2009 at 07:58 PM. Reason: convert to VBulletin format
SmokeyWren is offline
post #5 of 23 (permalink) Old 11-15-2005, 12:25 PM Thread Starter
Thanks everyone for the help. I will check it out today since its not raining and let you all know what I found.
post #6 of 23 (permalink) Old 11-15-2005, 01:05 PM
Speeking of block heaters the cord on mine is junk. Can I get just the cord or is it a complete assembly?
Andy
03' F-250 4x4 7.3L PSD, Reg. cab, 6 spd, Silver.
4" dp 5" straight thru, Autometer gauges, DI 4 pos. chip, Wicked Wheel, Edge Mini spring pack, 315-75x16 BFG AT's.
68' Bronco, uncut, 289,
3.5" lift, 31-10.5's, No ps or brakes.
70' Z-28, 350 4 spd.
68EB is offline
post #7 of 23 (permalink) Old 11-15-2005, 01:45 PM
My Photos: (31)
You might want to try one of THESE WOLVERINE HEATERS.
F250 CC PSD, 6-Spd, 4x4, DP Tuner 4 Pos Chip, 4 BD Cat Back, Cat Delete, 3.5 Down Pipe,
, ITP Fuel Sys,
, Home-made Headache Rack,
289 4-Speed 9"
Fat Diesel is offline
post #8 of 23 (permalink) Old 11-15-2005, 04:56 PM
My Photos: (18)
Wolverine is the way to go, I do not even use my OEM block heater any longer unles it is going to be way below zero.
garyT
garyt is offline
post #9 of 23 (permalink) Old 11-15-2005, 07:36 PM
klhansen's Avatar
My Photos: (180)
Yes, you can just replace the cord. Or if the plug-in end is bad, you can just cut it off and wire on a Marinco Charger Inlet
Makes plugging in easy - Look Ma, only one hand! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #10 of 23 (permalink) Old 11-15-2005, 09:19 PM
heating the coolant is a LOT better then heating the oil. Heating the oil can burn the oil. Besides, warm oil doesn't help the engine start.
heating the coolant using a block heater means the HEAD will get warmer. Most of the water circulates up to the head.
Then when you crank the engine over to start it, the head is warm, top of the block is warm, vavles are already warm, and the truck will start more quickly.
99.5 Superduty Crew 4x4 6 speed Smokewagon
Pizza cutter tires, Tymar, BTM, DP
If it don't run, chrome it.
drmiller100 is offline
post #11 of 23 (permalink) Old 11-15-2005, 10:20 PM
in the winter months here, it does get cold, however, i have mine setup on a timer, i plug it in at night, but the cord going outside doesnt kick the juice on till 2am, that lets it run for 3 1/2 hours before i fire it in the morning, i see no need to leave it plugged in all night, and it was a pita replacing the one on my dads old 91(i cant really rember for sure, but i think it was) and i dont feel the need to pay for the electrical usage, within the 3 1/2 hours its plugged in for, it will melt the snow on the hood, that usually tells me its working, and yes, my cord ends to get alittle warm.
There was no brite light at the end of the tunnel for me.
mattA is offline
post #12 of 23 (permalink) Old 12-16-2009, 11:57 PM
I am looking for suggestions for installing and circulating coolant heater. Anyone got some ideas/instructions/locations for taping in?
JECHKAEL is offline
post #13 of 23 (permalink) Old 12-17-2009, 08:06 PM
SmokeyWren's Avatar
My Photos: (45)
If it's your 2002 you're talking about, you already have a circulating coolant heater, the so-called block heater.
Look at the photo in my earlier post. If yours has that orange cord coming out of the base of the oil filter, you already have the block heater and the cord to plug it in. You just need to find the plug end of that cord behind the front bumper and plug it in.
If yours doesn't have that orange cord, then all you need to buy is the cord. The heating element is already there. The special cord for the block heater is higher than a cat's back, but it's a lot cheaper that buying a whole new block heater.
post #14 of 23 (permalink) Old 12-17-2009, 10:29 PM
Flywheel's Avatar
What are you looking to do?
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #15 of 23 (permalink) Old 12-17-2009, 10:50 PM
AndrewExe's Avatar
is the 00' the same way
2000 F350, freightliner bags, 6" lift, 35x12.50 open country m/t, custom gooseneck for a custom crane, rear diff guard, banks quick spool elbow, x-wheel, 140hp/357# tuner ,5" turbo back straight
AndrewExe is offline
