SCT Pyro issue - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 01-18-2017, 11:22 PM Thread Starter
jricherson's Avatar
My Photos: (14)
SCT Pyro issue
I just bought the 2002 listed in my sig and the SCT X4 7015 works ok but the JMS 9617 EGT probe is having issue. I set it to the SCT EGT with Red Firewire but the temp is not accurate. Even running at 55 the EGTs are around 300 F and I know from my ohter 2 trucks this is not right!
I have not worked with the SCT tuners before and have read a lot about them but not found an answer to this issue. I prefer an actual gauge but since this truck had this already on it I will use it till I upgrade to the Hydra and Swamps injectors.
I got this for my son to drive but want the EGT gauge so he can watch his throttle.
2001 F-250, 4X4, SWB, 7.3L, Crew Cab, MBRP 4" exhaust, Tymar intake, Swamps 175/146 single shot injectors, Driven Diesel Regulated Fuel Return, PHP Hydra Chip, Mechanical Waste Gate, Gutted EBPV, Deleted EBPV Pedestal, BTS tranny, 6.0L tranny cooler, RedHead steering box, Plenum inserts, RiffRaff upgraded clamps for intercooler boots, RiffRaff intake sleeves, CCV bypass from RiffRaff, boots from RiffRaff, Ride Rite Air Bags, Guzzle's Monster Relay mod, 1.0 A/R turbo Housing.
1996 F-250, 4x4, SWB, 7.3L, Supercab, Tymar, AFE Big Bore 4" exhaust with 3"-4" DP, Swamps 150/146 Injectors, PHP Hydra Chip with Swamps tunes, Terminator T500 HPOP, Beans D66 Turbo, HPX Crossover, EBPV gutted, EBPV Delete Pedestal, shimmed FPR, Carr Hoop Steps, Cab Lights, Limited Slip 4.10 rear end.
2002 F-250 4X4 Extended Cab Short Bed California truck, AFE 4" Exhaust, Tymar intake, Leveling Kit, Swamps 175/146 Single Shots, HydraChip with Swamps Tunes, Wicked Wheel, Mechanical Waste Gate, Gutted EBPV and deleted pedestal, RiffRaff intake sleeves, RiffRaff boots and clamps, BTS Transmission and 6.0L cooler.
2002 F-250 4X4 Extended Cab Short Bed, Swamps 175/146 single shot injectors, Hydra chip with Swamps tunes, RiffRaff FRx Fuel regulated system, 1.0 A/R Turbo Housing with high flow outlet, BTS Transmission with 6.0L cooler, 4" Exhaust, Tymar intake, RiffRaff boots and clamps, Wicked Wheel
jricherson is offline
post #2 of 9 (permalink) Old 01-21-2017, 02:34 PM
yan7gin's Avatar
Are you sure that you have the probe? Just asking because I know that the sct is able to display egt but you have to buy the probe to make it work.
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 9 (permalink) Old 01-21-2017, 08:57 PM Thread Starter
jricherson's Avatar
My Photos: (14)
Yes there is a probe. I cleaned the connection to the firewire module and the probe itself to the manifold. I found that there is possibly an issue in the metal braided cable from the pyro. I can move it and there is random readings from 1700 to 34. I think I need a new pyro cable.
post #4 of 9 (permalink) Old 01-21-2017, 09:27 PM
yan7gin's Avatar
Ya that would be a good sign
F350 2002 7.3
yan7gin is offline
post #5 of 9 (permalink) Old 01-25-2017, 06:52 PM
Yes, it sounds like you need an new thermocouple. Maxing out to 1700 would usually indicate a bad ground or bad connection of some sort in the shielding.
post #6 of 9 (permalink) Old 01-26-2017, 12:25 PM Thread Starter
jricherson's Avatar
My Photos: (14)
The pyro seems to be the issue. I really do not like this SCT Programmer because there are not a way to set alarms. I have used the Edge CTS and loved it in the past before upgrading injectors to single shots and now use Hydra/Swamps and gauges.
I think if I am needing to replace the pyro ($150), might be a good time to switch programmers and start over. My 15 year old is driving this truck when he turns 16 and would really like to have an audible alarm on the pyro until he gets a feel for temps and driving.
Thank you for the help.
post #7 of 9 (permalink) Old 01-26-2017, 01:01 PM
yan7gin's Avatar
To me sct is better than edge. Never really was a edge fan.
The best for the 7.3 is to run custom tune. If you want an all in one (tune and display) i would highly recommend the infinity Dx from DP tuner. Justin can help you with that.
F350 2002 7.3
yan7gin is offline
post #8 of 9 (permalink) Old 01-26-2017, 01:13 PM Thread Starter
jricherson's Avatar
My Photos: (14)
I know canned tunes are not preferred. I am just buying time until I need to replace injectors with single shots and will get custom tunes then. I just want a boost in performance and gauges for now.
I have used DP in the past to reflash my 96 pcm and have nothing but great things to say. Jody was really helpful and got me back on road quickly after an issue with bad PCM.
post #9 of 9 (permalink) Old 01-26-2017, 06:57 PM
Yes, and with the Infinity you can set an audible and visbile alarm for your EGT gauge. Just one nice feature of it.
We can do your custom tunes when that time comes too.
