Shock Change - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-09-2006, 12:17 PM Thread Starter
Shock Change
Need some help finding a good part number. In the process of changing to Blistein shocks and the found most of the part numbers for new mounting nuts and bolts in the CD m/m I have. But, the part number N811623-S307, a nut and retainer assy, used to attach bottom of front end shocks. The bolt was so tight/rusted that I had to break off the lock tab to remove the nut. Have tried several Ford part sites but no help in crossing the number. Anyone got a suggestion? Thanks.
Y2K,(built 8/99)F250SD,SC,Lariat,4X4 Off Road,LWB,PSD,ESOF,3.73,A/T,Woodland Green,LINE-X, Sho-Me ign override, DRL,Western Diesel Chip,Raider Canopy,Amsoil Dual by-pass, Amsoil throughout, Cyclops anti-theft system, SPA digital EGT,BOOST,TT, and Rearend Temp.gauge with MAG-HYTEC cover,Isspro TTM, Cryo-Treated front Rotors, MAG-HYTEC transmission pan, Bilstein shocks.
Redbird is offline
post #2 of 3 (permalink) Old 12-09-2006, 01:36 PM
Re: Shock Change
Try this website
http://www.powerstrokeshop.com/
If you can't find it, call Bob at the powerstrokeshop he can probably dig it up for you.
'03 F250 CC333hp on Dunbar's rollers, stock injectors, stock oil, stock turbo (1.0 ex hsg) and DP Tunes
Garmon's Diesel Perfomance (Bang Bang Bang)
Slower than pig snott #1
ditch_dawg is offline
post #3 of 3 (permalink) Old 12-09-2006, 05:04 PM
Feedback Score: 3 reviews
Re: Shock Change
Just use a reg bolt and nut [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Cary
caryt is offline
