Stage 1 Vs Stage 1.5 injectors - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 02-11-2019, 05:20 PM Thread Starter
My injectors in my truck are getting worn out, running rough when its cold etc.
So I figured I'd upgrade to some bigger injectors.
I am stuck, I cannot decide what stage injectors I should choose. They will be full force injectors.
Stage 1 seems great. A little more power, and you can use stock drive train parts.
Stage 1.5 seems good also. A lot more power however I am wondering if my stock turbo can handle it? Also I expect to eventually have to replace the transmission either way in the future. I have the money to replace it if it does go out but of course if I drive normal I hope it will last as long as possible. Will the 1.5's kill the transmission easily?
I am thinking I should go for stage 1 injectors but I hear that people are disappointed in the power not being that big of a jump.
In the end I don't need huge power. (but it is fun) I will occasionally tow a travel trailer or 5th wheel (I am still looking around for them.) I don't plan on getting anything heavier than 10k. I know you can keep the 1.5s tuned down somewhat if needed for towing.
I know this wasn't written very organized but its what I could do.
2002 F250 7.3L Extended Cab Long Bed, PHP hydra, Gauges, EGT, Trans Temp, Straight Pipe, 6637 Filter
02_7.3 is offline
post #2 of 6 (permalink) Old 02-12-2019, 08:09 AM
Whiskyb's Avatar
I'm at this point in my replacement engine build. Been scratching my head as well. 1.5's are very little money more so it is tempting. Hopefully someone with way more knowledge jumps in
Whiskyb
2001 F350 4X4 Super Duty PSD Dually
Almost 400k and still given her
DP Tuner
and guages, DIY air intake, BTM,
Dieselsites trans and coolant filters
Wicked wheel 2 (Gone) , Guzzles billet fpr
Whiskyb is offline
post #3 of 6 (permalink) Old 02-12-2019, 08:31 AM
2000F250-7.3's Avatar
I can’t talk for people who went to stage 1. I went with stage 1.5 from full force diesel on a stock turbo I had some trouble keeping egt’s in check towing in Colorado but the turbo held up I had good tow tunes witch helped. My set up now is hydra with 1023 Diesel tunes with a GTP38R adrenaline HPOP Built 4r100 4inc exhaust stock intercooler. My set up now works real well at keeping Egt’s down and lots of power towing.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #4 of 6 (permalink) Old 02-12-2019, 12:59 PM
blue99stroker's Avatar
I also have 160/30’s
I had two major trans failures in the first 2k miles.
I stripped out the forward drum which is common over 350hp. Installed a E4OD long spline drum instead of the 4r100 half spline unit.
Then i Grenaded a triple disk ford reman converter.
Trans temps never went above 180 and it had a modified VB and larger cooler. No warning on either failure.
This was only on a 3.7ms tune 360-370hp.
I also had higher egts than I liked with a billet wheel and ebpv delete 1400-1500 degrees and high boost/drive pressure
So I ended up swapping on a van turbo. But the 38r (with wastegate tightened way down) performs even better.
For just a mild truck I would do a 160/0
A 350hp 7.3 is fun to drive.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #5 of 6 (permalink) Old 02-22-2019, 10:50 AM
BS Hauler's Avatar
I am going with 180/80 's . Why spend all the work and money and not go to a 180 over the 160.. Your foot is controlling how much fuel you are using.
02 F350 Lariet CCLB 4wd Dually 7.3 6sp M. 122,000 miles, Manual hubs and transfer case.
Stock as of yet. So far have bought
4" MBRA turbo back with muffler
GTP 38R BB turbo and WWII wheel and high flow housing, Non EBV pedestal, Adrenaline HPOP.
New IH up-pipes, Aluminum intake plenums, 203* Therm with aluminum housing, Boost relief valve, all new boots, FPRx and HPRx. Coolant and Trans Filter kits. Max AC Assist control Valve. 8 gauges,
Boost,Pyro,Fuel,HPOP,LPOP pressure. Water,Oil and Trans Temp. Need tunes and injectors yet.
03 26' CM 4 Horse trailer and 25' GN flat bed.
06 F-350 Lariet CCSB SRW 4wd Auto 6.0 78,000
miles. Atlas 80 with Ed's lifetime, Blue spring, MBRP 4" turbo back with muffler, Bully Dog for monitoring. So far no problems.
BS Hauler is offline
post #6 of 6 (permalink) Old 02-23-2019, 06:18 AM
Your not gong to find many tuners that will recommend that size anymore.
180/80’s make 25 more hp than 180/30’s at the cost of torque and heavily taxing the HPOP.
Stick with 180/30 or jump to 200/80 hybrids.
Similar Threads
Stage 1 injectors mxer333 '99 & up Upgrades and Aftermarket - 7.3L Engine 0 02-06-2011 09:00 PM
Injectors.. stage 1 or 2 RIStroker2000 '99 & up Upgrades and Aftermarket - 7.3L Engine 17 05-22-2010 11:51 PM
stage 1 or stage 2 DIY injectors? beechya475 Power Strokes 1994-1997 Upgrades and Aftermarket 7 09-20-2007 11:01 PM
Injector's stage 1's, 2's and Hybrids with aftermarket /modded pumps caryt Power Strokes 1994-1997 Upgrades and Aftermarket 4 06-12-2005 09:12 AM
