Sucking noise from Volant air box - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 06-14-2017, 02:17 PM Thread Starter
I have a 2001 F350 7.3 with the Volant closed box filter, DDP injectors, MBRP 4"exhaust, and a Bullydog programmer. When I'm pulling our rv (13k#) and have to get on it up a hill it makes a sucking noise, egt goes up, and boost goes down. Any ideas?
Thomas Lucher 2 is offline
post #2 of 9 (permalink) Old 06-14-2017, 02:53 PM
blue99stroker's Avatar
Are you hearing turbo surge?
Do a search on YouTube.
Also, what type of DDP injectors did you buy.
Specifically what cc and nozzle size
Like 160/0 or 160/80?
Unless you got your bullydog retuned they won't work well
blue99stroker is offline
post #3 of 9 (permalink) Old 06-14-2017, 03:41 PM Thread Starter
DDPs website says they're similar to a 140cc with 25% nozzles. I haven't had any turbo surging. I'll have to look into the Bulldog issue. Thanks
post #4 of 9 (permalink) Old 06-14-2017, 04:58 PM
The smallest aftermarket nozzle is a 30%.
They are probably stock AD's with a 30% nozzle slapped on.
Unless you had the bullydog retuned for the nozzle change it's not making much of a difference.
Post a video of what you hear. I'm not quite sure on the noise.
It's not the fan clutch engaging is it?
post #5 of 9 (permalink) Old 06-14-2017, 04:59 PM
It also could be the ebpv closing for some reason. What does boost drop too?
Have you done a boost leak test
post #6 of 9 (permalink) Old 06-14-2017, 08:53 PM
yan7gin's Avatar
I would highly suggest that you get something better than the bullydog. This unit is terrible for your truck
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #7 of 9 (permalink) Old 06-16-2017, 12:58 PM
Yes. Off the shelf tunes do not work very well, especially with larger than stock injectors.
To the OP... You may be hearing a boost leak. It is pretty normal to hear the air whoosh through the intake, especially after a shift. However, if your boost is dropping and EGT's go up when you hear this noise, it is probably a boost leak.
Turbo surge sounds like a very fast chirping noise. As stated, you can find examples of this on YouTube.
post #8 of 9 (permalink) Old 06-16-2017, 10:35 PM
[QUOTE=yan7gin;4427586]I would highly suggest that you get something better than the bullydog. This unit is terrible for your truck
I had a Bullydog on my truck, sent it back because it died. Reinstalled it, but too much black smoke. It's resting in the top of my tool box. I run a Banks six gun stacked on a Big Hoss tuner from Banks as well. It works great and it will change tunes on the fly.
mbrahmer is offline
post #9 of 9 (permalink) Old 06-17-2017, 11:46 PM
yan7gin's Avatar
[quote=mbrahmer;4428674]
You need a chip with custom tune. Way better engine and trans tuning
F350 2002 7.3
yan7gin is offline
