Superchip 1845 Question - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 8 (permalink) Old 12-30-2016, 06:38 PM Thread Starter
KISS_Racing's Avatar
I did some reading on here about Speedometer Recalibration then called both Superchips and SCT. Both were very helpful and great customer service. I currently have a Superchips 1705 Tri-Mode Tuner and I'm leaning towards the 1845. Anyone have any feedback on the 1845 and what luck have You had with Speedo Recal?
KISS_Racing
* 2002 F-350 4X4 Loaded...~ 8" BDS Lift with FOX Shocks, AFE Magna-Force~1705 Tri-Mode/Stacked On "The Pill" (to help the flat spot)~Bully Dog SS Exhaust~Isspro Pyro, Boost and Voltage Gauges...
KISS_Racing is offline
post #2 of 8 (permalink) Old 12-30-2016, 07:05 PM
yan7gin's Avatar
I'm not a fan of superchip but SCT is good.
I use AE to recal the speedo.
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 8 (permalink) Old 01-05-2017, 07:35 AM
blue99stroker's Avatar
The 1705 is ok for an older programmer.
But custom tunes will be much better
blue99stroker is offline
post #4 of 8 (permalink) Old 01-12-2017, 06:53 PM
You can have Ford recalibrate the speedo for a fee. And then you can pick up a chip with custom tunes (we can help you out here). You will be much happier doing that.
Let me know if you have any questions we can answer for you.
post #5 of 8 (permalink) Old 01-13-2017, 07:51 PM
yan7gin's Avatar
I ask 3 dealers here and all of them told me that if the tire size wasn't an option for your truck year they can't or won't do it.
Sent from AutoGuide.com Free App
F350 2002 7.3
yan7gin is offline
post #6 of 8 (permalink) Old 01-17-2017, 05:03 PM
Then they do not know how to work Ford IDS (their software). You should be able to recalibrate up to a 35" tire. It is done through the ABS module. Jody does it all the time for guys locally.
If you have an OBS truck, you can recalibrate the speedo yourself without the use of any electronics.
post #7 of 8 (permalink) Old 01-17-2017, 11:19 PM
yan7gin's Avatar
I wouldn't be surprised. Maybe because i had 37" on... i got mine recall with AE
One of their "diesel tech" told me that 7.3 does not have injectors cups. That's where i hang up the phone
F350 2002 7.3
yan7gin is offline
post #8 of 8 (permalink) Old 01-18-2017, 06:14 PM
Yes, run as far away from that dealership as you can.
yan7gin likes this.
