Swapping to XF6 - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-05-2018, 09:39 AM Thread Starter
jmadigan's Avatar
Swapping to XF6
Im in the process of swapping from 4r100 to zf6. One question i have is will the late 99 pcm work in the 2001? Should i send the 01 in to get reburned to manual or just throw in the late 99 and call it a day.
2001 PSD 7.3
4x4
ZF6 swapped
Crew cab
TS6 with custom tunes from Jody at DP-Tuner
HPX oil crossover
6637 MOD
CCV MOD
4" Turbo back exhaust side exit
EBPV gutted pedestal and Valve delete
jmadigan is offline
post #2 of 3 (permalink) Old 12-08-2018, 08:39 PM
what is the model type of the late 99 pcm? and what is the type of the current pcm?
You can either keep the auto pcm and just jump the wires on the tranny connector or swap pcm's. a late model 99 pcm can work in an 01 but it might depend on the group type.
when I say group type...there is a DPC-XXX on the pcm. If for example, you have a DPC-422 auto pcm, I believe you would want/need a DPC-421 manual tranny pcm.
Trying the 99 pcm won't hurt anything and will let you know if there are any bugs, but without the DPC info, I can't tell you for sure. I personally would run the auto pcm before i sent a pcm to be reflashed, but it's your call.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans tuned/250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete, Pius LASB from Irate, Swamps HVHF IDM.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Baldwin PA2818(6637) RR Boots/CBillet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #3 of 3 (permalink) Old 04-30-2019, 11:40 AM Thread Starter
jmadigan's Avatar
Completed the swap and the manual PCM is running the truck but i have a ts6 burnt for the old automatic PCM would it be worth a shot to try to use the auto PCM and chip would it work okay? sorry for the late reply i havent been on here in a while.
2001 PSD 7.3
4x4
ZF6 swapped
Crew cab
HPX oil crossover
6637 MOD
CCV MOD
jmadigan is offline
