Thermocouple for Pyrometer? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 12-24-2009, 12:10 PM Thread Starter
indystroker's Avatar
I recently replaced my stock downpipe with 4". The previous owner drilled a hole in the factory downpipe and inserted the thermocouple into the downpipe and held in place with a band clamp, also with a hole through it.
I wanting to install it in the manifold, but I dont see how this one installs. There are no threads or adapters on any kind. Its about 2.5" long and the size of a pencil. The gauge is cheap Z series Autometer. How do I go about installing this in my manifold?
Indystroker
01 F-250 4x4, XLT, Crew Cab, AFE Stage II Intake
TS Chip w/ PHP Tunes, Auto Meter Gauges (pyro, boost, trans), ITP Fuel Tank/Pre-Pump Kit, Riffraff FRx, Gutted Turbo, Riffraff SS X-over, DIY CCV, 4" Turbo Back w/Donaldson M085171, Warn Hubs, Sonnax Kit
indystroker is offline
post #2 of 10 (permalink) Old 12-24-2009, 12:42 PM
chuckster57's Avatar
PRE turbo is much better
http://www.thedieselstop.com/forums/...-gauge-213772/
Go to about the 12th post. there will be a picture of where it goes on a PSD engine. Once it is installed you want to keep the EGT's below 1150 if you can. Pistons melt at about 1240 and since the gauge might be a little off, better to err on the colder side...
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 10 (permalink) Old 12-24-2009, 03:41 PM
SmokeyWren's Avatar
My Photos: (45)
As the photo in my previous post that Chuck linked to shows, use the same band clamp that was around the downpipe to clamp the thermocouple into a hole in the neck of the exhaust manifold. Yes, that means you have to drill a hole in the exhaust manifold, exactly the right size for the thermocouple to clamp into without flopping around.
Then 1,250 is the red line, so try to maintain about 1,200 when climbing a mountain pass with a heavy trailer. You control EGT with the pyrometer the same way you control speed with the speedometer. I.e., modulate the go pedal to keep it where you want it.
My Sierra Blanca (Spanish for White Mountain) in the sig pic was a great pickup for 11.5 years. I sold it several years ago. I drove a hand-me-down 2003 F-150 SuperCrew 4.6L 2V for a while, but it was unacceptable for towing more than a rowboat. Replacement is a 2012 F-150 EcoBoost SuperCrew Lariat that tows my 5,000-pound TT like a dream. Replaced the 2012 with a 2019 F-150 3.5L EcoBoost with max tow.
SmokeyWren is offline
post #4 of 10 (permalink) Old 12-24-2009, 09:58 PM Thread Starter
I noticed in the picture he had what appears to be a white gasket of some type on his thermocouple. What is it...is it used for an extra seal?
Indystroker
post #5 of 10 (permalink) Old 12-24-2009, 10:48 PM
SmokeyWren's Avatar
My Photos: (45)
You should be able to use the exact parts you remove from the downpipe to install in the manifold. Yes, that includes a gasket of some sort to help seal around the base of the thermocouple. You see his because that gasket is big and white, but if it was small and black it would still be there but you wouldn't notice it as much.
I suspect your thermocouple also includes some sort of gasket at the base of the thermocouple, but it may not be big and white and stick out like a sore thumb.
post #6 of 10 (permalink) Old 12-25-2009, 09:16 PM Thread Starter
I dont remember seeing one when I took it out of the downpipe. Is it made of anything special? If its missing, where could I pick one up?
Indystroker
post #7 of 10 (permalink) Old 12-26-2009, 10:12 AM
SmokeyWren's Avatar
My Photos: (45)
It's special in that it's a gasket but made to handle 1,300 without melting. Permatex RTV-type gasket makers give up the ghost at around 500 or 600, so they won't do the job. I'd contact Bob at DieselSite or David at Diesel Manor and ask them. Maybe some sort of a gasket material available at auto parts stores you could use to make your own?
post #8 of 10 (permalink) Old 12-26-2009, 07:14 PM Thread Starter
We have gasket material at my work, I'll check the heat rating on it.
Indystroker
post #9 of 10 (permalink) Old 12-26-2009, 08:00 PM
Kanman's Avatar
I believe that gasket is actually made of asbestos, they are soft and feel like fiberglass cloth. I sincerely doubt you'll find a sealer at your shop to take those kinds of temps, and not burn up within ten minutes. If ya do, lemme know I want some lol.
Call any of the sponsors on this board they can probably find ya an extra gasket laying around...
Kanman is offline
post #10 of 10 (permalink) Old 12-26-2009, 09:32 PM Thread Starter
I work at Aisin Brake & Chassis, we have ovens that bake an adhesive on the back of brake shoes to the shoe rim. Internals get pretty hot, 1200...I dont know. I do know we have gasket material for them. I work in the department that works on the machines, but I'm unsure of the exact rating of the material.
I emailed Autometer and maybe...just maybe they are in the feeling jolly mood and send me one for free.
Indystroker
