Tranny question - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 07-19-2013, 06:11 PM Thread Starter
jpciron's Avatar
Tranny question
I thought my tranny 4r100 was shot. I took it to the best transmission shop in town and they couldn't find anything wrong with it.
I felt like an idiot.
I bought the truck 55k miles ago and the problem hasn't gotten worse. It has 234k on it now. and I could not even get them to sell me a new transmission with the questions I was asking.
The problem I am having is, When going down the freeway and traffic slows or comes to a crawl, when I step on it the truck will rev till red line and go nowhere. The egts will hit 1000 if I let them.
I was also considering the turbo a problem. When the truck is dogging it my boost is at less then 5 psi. Could A turbo not spooling up properly cause a lag in shifts?
Any help or advice will help us out tring to get 500k out of this truck.
Thank you
JPC
2003 7.3 F-350 XLT 2WD CC, 285,000K,4" Back~ 6" S.S. Miter Stack, International bellowed up pipes, K&N Intake W/Riffraff 6637 Filter,Ebpv delete,Garrett38r Turbo, Garrett high flow outlet, Stage 1 Injectors, PHP Hydra W/GearHead Tunes, Riffraff Plenum inserts, , Riffraff IC and plenum boots, Powder Coated Blue IC Tubes, Pricol Optix- Pyro,Boost,Trans , Hutch and Harpoon mod, Baldwin pre-filter,Rear Shackles,Custom box 12s behind rear,Kicker,Bluray,HDTV's
"The Constitution shall never be construed to prevent the people of the United States who are peaceable citizens from keeping their own arms."
jpciron is offline
post #2 of 4 (permalink) Old 07-19-2013, 06:23 PM
Mark Kovalsky's Avatar
My Photos: (6)
Yes, a turbo not spoiling up will cause shift issues like you're seeing.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 07-19-2013, 06:53 PM Thread Starter
jpciron's Avatar
Mark
Thank you for your reply.
I know you are a transmission guy and don't get into motor issues.
But do you think I am on the right path in my thinking? The tranny shop was impressed with my maintenance on the truck.
I thought there was something other then the transmission causing the shifting issue.
Thank you for your help.
jpc
jpciron is offline
post #4 of 4 (permalink) Old 07-19-2013, 09:20 PM
My Photos: (6)
Yes, you're on the right path. Fix what's wrong with the engine and that will fix the trans, too.
Mark
Former
